Re: Les' Build
Hi Les,
I was using perlite/cement (5:1) under the floor. I've used mixer - put the perlite, then cement, dry mix the ingredients, then add some water.
4 inch was very easy - I've bought 2 ply blanket, after unpacking it "inflates" to 4", didn't have any problems with fixing it and shaping on the dome.
Re: Les' Build
I mixed it DRY first, then the water...in a wheel barrow, was either 5-1 or 6-1. I used chicken wire, and yes, it is a bitch to get it to stay in place. Be sure to start at the bottom, pack it in the full depth that you want and gradually work your way up. I found this process to be one of the most tedious of the entire build - even though it only took a couple of hours, seemed like days......you just have this thought in your head that you can slap in on and be done in no time.......NOT TRUE.
Hang in there...have a beer, pack it in, have another beer.........repeat till complete.
RT
Re: Les' Build
Do not do this!
I failed miserably. I thought if I made the mortar thick, I could skim it and then pour in some more insulation - WRONG.
The lath flexes and the mortar will drop into the cavity. I want to try and use a vermiculite/portland mix to add more insulation (I don't believe I need more but it was in the plans). For those that have been here, whats the best way to mix it. Bucket/wheel barrow? I believe I read that it is a 5/1 mix.
Thanks.
Les...
Re: Les' Build
Elisabeth - I have a picture of the jig I made in the photo gallery. Took a little bit of muscle to form it but not too bad. If I could have bought the 1/4 in instead of 3/8, it would have been a lot easier.
Dvonk - I didn't enjoy working with the 1 inch product, don't know how you did 4. That is some serious insulation.
Les...
Re: Les' Build
How did you get such nice bends on the rebar? Mine always look like a drunk did them.
The metal lath can be extremely sharp indeed. Be very careful with your knuckles when you are applying your scratch coat. Several years ago I did a faux stone fireplace for a house we built, and my poor knuckles just didn't have skin for days. That was with gloves. Went thru several pairs- unlike the usual, where I wear out the palm side, I tore off the backs!
Your whole project is so well done, you should feel a tremendous satisfaction in it! Even if you're just heating up a can of beans... (which will need to be vented, btw, unless you wanna clean up bean mess...)
Re: Les' Build
The idea of the frame is clear, sure
ps. my blanket is 2 ply, one layer is about 4"
Re: Les' Build
I used 2 rolls of 1 inch blanket. In some spots I am 3, maybe 4 inches thick. I didn't feel comfortable laying the stucco onto the blanket - seems to be a weak spot for cracks. That's why I built the frame out of steel, just my approach.
Les...Last edited by Les; 07-15-2008, 09:42 PM.
Re: Les' Build
I've meant that if your need extra insulation just go for the second layer of the blanket - it's much more efficient and easier to deal with compared loose insulation.
I've run my oven twice, the second time I've use a door to seal the heat in - and it was pretty hot two days later. One 4" layer of blanket was just bit warm. I'm going to cover it with a second one and go for stucco.Last edited by dvonk; 07-15-2008, 09:29 PM.
Re: Les' Build
Overkill - more is better. If I can come out 48 hours after a fire, and cook something, that would be awesome (maybe just heat up a can of beans ) My weak point is the door - I was planning on 4 inches but the math doesn't allow it unless I get really creative. Anyway, it was in my plans - I feel compelled to follow it.
Les...
Re: Les' Build
Thanks Jim - it's all about the fire.
Is there anything easy about this project (except making fire, that was cool). I thought I could simply cover the lath with foil to prevent the vermiculite from escaping - not. The wind blew it all over the yard. Plan B: cover this first course with mortar and pour it in - then go to the next level. Working with this lath is like playing with a box of razor blades.
Les...
Re: Les' Build
Another Youtube attempt. This was on Saturday night. I brought it back up to high temps to see if the cracks would grow - they remained pretty much the same. I spent yesterday starting the insulation process. I am going to add 12 more inches to the height of the flue incorporating a taper ( got that idea from David) If it draws this well like it is - it can only get better.
YouTube - The second fire
Les...Last edited by Les; 07-15-2008, 07:43 AM.
Re: Les' Build
Thanks! I replace my link with yours. Youtube has issues - people have been able to view it, then it breaks. Pretty strange.
Les...
Re: Les' Build
Still couldnt view it so I played with the link and came up with this one. Works for me so hope it works for yall.
http://www.youtube.com/swf/l.swf?vid...A//i.ytimg.com
Looks awesome!! at least you got the video before camera melted LOLLast edited by CajunKnight; 07-12-2008, 02:54 PM.
