Hi David, thanks for responding! - I will follow your recommendation on #1, and have a follow-up on #2 - Sixto.
I agree also with your note about question # 2 under typical WFO operations. I'm was thinking about two potential situations:
A) Using the oven as a smoker, or
B) Keeping a throttled-down fire overnight to save time and effort to reach a specific temperature in the morning (above and beyond the natural cooling of the dome) I was thinkiing of keeping a couple of logs in the dome overnight.at a slow burn rate, (just enough oxygen moving through to keep combustion going) with an insulated door in place to keep in most of the heat that's accumulated during the day, but let some (dampered) smoke escape either through the upper edges of the insulated door or a more controlled "window" cut into it.... The side combustion inlet would be closed off when the oven mouth is open and I'm tending the fire again...
(B) is something similar to what I currently do for my sealed-insulated fireplace, that is to choke down the air intake and the damper to promote a slow burn overnight... most of the wood burns while I sleep, keeping the firebox warm when I check it in the morning.)
I also wonder if I'm overthinking it. For example: if the oven is at 200d to 350d in the morning and I need 500d it may be easy enough to light it up again in the morning to build temperature relatively quickly.
