Hi, just found this at my local homedepot, a HEBEL mortar for the instalation of HEBEL products. The salesman said that it would practically solidify into an almost identical HEBEL block. Does this mean I can use the mortar and smother it over a 1 inch layer of ceramic blanket and that way the final stucco layer would be less prone to cracking? Or even cast a 2 inche piece and set it under the firebrick floor.This would be so much cheaper.
SECTION 3: COMPOSITION / INFORMATION ON INGREDIENTS
Chemical Name: / Synonyms: / Proportion: / CAS Number:
Graded sand containing crystalline silica / Quartz / 50-70% / 14808-60-7
Portland cement / GP Cement / 10-30% / 65997-15-1
Blast furnace slag / Slag / 10-30% / 65996-69-2
Non hazardous ingredients / N/A / 5-10%
DATA SHEET
Microsoft Word - Hebel Mortar.doc
DATA SHEET
