42" Corner Build in Southern Missouri
  • Buzzard Bluff
    My local big box store has Portland Type IL in stock. Is this an ok substitute for traditional Portland type 1 or 2???
  • Buzzard Bluff
  • Buzzard Bluff
  • Buzzard Bluff
    Was able to get the tile, insulation and floor laid this week... Slow going but it's fun watching the thing come together.
  • Buzzard Bluff
    Thanks Smokamatic, I'm sorry but I'm not certain what the pitch of the roof is. I'll try to get a measurement for you. The chimney is already flashed into the metal roof and I'll just have to make sure the oven lines up to go through the center of it. The roof begins a few feet above the eave. Here's a picture that might help.
  • Smokamatic
    I really like your roof design. What's the pitch? Will your flue go thru or around the roof? We want to do something similar because our oven is almost, but just not 100% waterproof. Ours will come off the side of an existing gable above its gutters. Can the WFO roof float about 1-foot above the gable's side?
    Thanks for the inspiration!
  • w650gb500
    Looks very similar. Even though my oven has counter space on both sides, it still isn’t enough room to prep wood on one side and pizzas on the other. Next time I will build it with 4-5’ on each side. Click image for larger version
  • Buzzard Bluff
    david s.... I think you can see the four holes I drilled in one of the above pics. I marked where the rebar was before removing the forms so I wouldn't hit them with the drill bit. I'm sure it was much easier after three days instead of after the concrete has cured.
    If you’ve not already cast in some weep holes in the slab, do yourself a favour while the concrete is still green and drill a few weep holes around 12mm diam through the slab. Start with a smaller diameter pilot hole to reduce break outs and if you hit steel you can try another position. Breakouts are better on the topside of the slab to assist drainage, so the drilling is better done, starting on the underside.
  • Buzzard Bluff
    And...... Finally got the hearth poured last week.
  • Buzzard Bluff
  • Buzzard Bluff
    It's been a busy summer with work, family and other projects but I was able to get the roof over the oven project built in June. Our good friend and contractor had us on the list for months. We think it was worth the wait and will be a help to me during the rest of the oven build.
  • Buzzard Bluff
    Thanks David.... I'll add another cross bar per your suggestion. hillscp, great idea with the vertical addition to your lintel. That really does look finished.
    Mike.... I will remember to shim under the supports. I have a contractor helping with the pour due to a slight injury I picked up mixing the concrete for the cinder blocks. What an asset to have all of your combined experience. Much appreciated.
    Steve
  • SableSprings
    Originally posted by Buzzard Bluff View Post
    Thanks for the input. Mike, I already have a 2x6 mid span under the duroc but if you think another upright in the center is warranted, I'll stick one in there.
    I could only see the front support for the durock, so if you've got a mid span one as well you should be golden...just don't forget the shims
  • hillscp
    That's how I did it too, but I poured the lintel before the hearth and I poured supports under it. Were both doing corner builds. I think it looks more finished with parallel sides for the opening under the lintel.
    Here is my build thread
    https://community.fornobravo.com/for...build-chico-ca
