Pompeii Oven floor from Forno Bravo
  • mfiore
    • Oct 2007
    • 919
    #16
    Re: Pompeii Oven floor from Forno Bravo
    Yes, you can put the insulation just under the igloo. Be sure it is under any part that gets hot (dome walls, floor, landing, etc.). This is what is done if you use an insulation board rather than the vermiculite/concrete.
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
    • connie kokiousis
      • Sep 2008
      • 15
      #17
      Thank you so much. I thought that this made sense, but I couldn't find anything in the directions or postings about it.
      Best Wishes,
      Connie
      • tommy5
        • Jun 2006
        • 36
        #18
        does anyone know if you can cut these tiles to fit a casa oven?
        • Les
          • Sep 2005
          • 2945
          #19
          Tommy,
          Anything can be cut if you have the proper blade, refractory materials are pretty easy (compared to something like porcelain).
          Les...
          • jerrycook
            • Sep 2008
            • 20
            #20
            I found a supplier in the San Francisco Bay Area that has 24" X 36" X 3" firebrick tiles at $81 per. I am considering using them for my oven floor to minimize the number of seams. I'm not sure how I will be able to cut them to fit and set them up for diagonal seams. I like the look of them though.
            • james
              Brick Oven Merchant
              • Mar 2005
              • 4648
              #21
              We use firebrick tiles in the Primavera oven. It's a nice material, it cooks great, you don't have too many seams, and they look really cool! We do cut them and fit the oven dome around the floor -- so it can be done. :-)
              • jerrycook
                • Sep 2008
                • 20
                #22
                  #23
                  Cutting big masonry slabs is a pain - they don't fit on the wet saw, and using the angle grinder to score and break is crude at best. You could take them down to the stoneyard and have them cut them to shape on their giant diamond saw, but that's not cheap.
