We have located a source for 18"x12"x2" high duty firebrick slabs for use as the Pompeii Oven floor. They weigh 32.6 lbs each. I am happy with the 2" thickness, and don't think we need to go to 2 1/2" for residential ovens. There are a number of advantages of using these slab, compared with discrete bricks.
1. The larger pieces replace roughly 6 9"x4.5" firebricks, greatly reducing the number of seams inside your oven.
2. The larger pieces are easier to get level than the individual bricks, making it easier to place your floor.
3. Handling many fewer pieces makes it easier to assemble your floor.
4. The firebrick slabs are high duty brick, which are more dense than light duty (fireplace) firebricks and have a higher alumina content, so they will last longer and will be more efficient at absorbing heat.
The cost will be more than the cost of the discrete firebricks -- due to both the more expensive material and the more complicated, lower volume production process, but I think it will be worth it.
Final specs, prices and photos will be coming soon, so if you have started an oven, and haven't bought the floor bricks yet -- think about using these. We will let you know when we have them in stock, and we will be adding them to the FB Store.
Pretty cool (or really hot). :-)
