42” Corner Build in the Shadow of Mount Nittany
  • Nice job. I am very excited to start cooking different things in the oven. And yes it cool down works great for seasoning cast iron pots and pans. On the firing side it also works great for removing all seasoning too. Ask me how I know...
    Randy
    • A little follow up:
      Did the first full firing of 2024 for Father's Day and made 10 pizze. Baked 4 loaves of Italian and 4 NY Deli Rye the next afternoon.
      My thermometer reads the dome temp on the opposite side of the oven from where I keep my fire so the temp initially increases early in the timeline as the heat distributes through the dome.
      I'm going to collect data for each firing and see how my changes impact the temp curve. Pizza then breads that need 500oF are easy to manage. I'm interested developing a schedule to have other breads ready to bake as the temp drops without recharging the oven.
      This was the first time using the insert after a full firing and I know I pushed the limit regarding combustion, but I wanted to see the impact of the insert on heat retention I'll need to replace the inside face and will probably hold off using it until the temp drops below 450 oF the next time. The boards were already charred and shrunk from the low firing I did to wake the oven up from its winter slumber. After 5 hours at over 500 oF the wood was quite toasty. It continued to snap crackle and pop for a few hours after it was pulled. You can see the progressive damage in photos 5 & 6.
      The reason I'm working with wood is to keep things a little "old world". However, I do have CaSil and FOAMGLAS on the inside ​.
      I am intrigued by rsandler 's use of Nomex for his door covering and may investigate that. Though my steel door has a gasket, the felt would allow me to close the small gap between the wood and arch around the insert that I need for expansion.
      For those of you who have followed this build, the cost per pizza/loaf is now down to $92.15
      Date Time Oven temp oF Oven temp oC Outside temp oF / oC Activity
      06-16-24 1700
      650 (Floor)
      343 (Floor)
      80 / 27
      Pizza
      2100
      485
      252
      75 / 24
      Placed steel door
      06-17-24 0900
      520
      271
      68 / 20
      Added door insert
      1400
      500
      260
      89 / 32
      Removed insert
      1700
      480
      248
      91 / 33
      Baked bread
      1900
      460
      238
      89 / 32
      Baked bread
      06-18-24 0800
      380
      193
      73 / 23
      Baked breakfast casserole
      1300
      360
      182
      88 / 31
      2100
      320
      160
      80 / 27
      06-19-24 0900
      275
      135
      78 / 26
      1600
      250
      121
      88 / 31
      2200
      235
      113
      80 / 27
      06-20-24 0900
      205
      96
      73 / 23
      1600
      195
      91
      91 / 33
      • Giovanni Rossi congratulations on getting to under 100$ per pizza. That means you are using the oven a bunch. I have been kind of lax on keeping track of just how much I have been spending. I have been pulling money from my vacation holiday account from work. This way the finance committee doesn't see the true cost and isn't as worried about it. Plus this way it is all paid in cash and is not financed. My rough guess is that I will be around 8-9K maybe 10k with patio for the whole thing. Not to badmy guess is I would be looking at 40K plus to have this built for me. The last oven I stopped keeping track at 6k and just said that is what it cost. I would guess it was actually closer to 7k and that was 9 years ago and I didn't have to build a patio. So this time I am doing pretty good at keeping costs in line.
        Randy
        • Good looking breads. I have tried, without success, doing bread. I want to be like Sable Springs
          • Another indicator of the benefit of firing the oven during a heat wave... still 120oF 7 days out!
            Should be pretty easy to recharge it for pizza. It usually takes about an hour to get the dome bricks at the thermometer location to that temp from a cold start.
            • Some final (though probably not) touches:
              Applied a log home oil product to the pressure treated parts of the pavilion for a little color to give more contrast from the knotty pine ceiling. Hopefully it will also discourage the carpenter bees that have already put a half dozen holes in various locations.
              Also extended the low-voltage line from the stone wall (while rebuilding it) to add some task and accent lighting.
              Lastly, made my first attempt at baguettes...need a little more practice!
              • A few more finishing touches. Made some simple peg hangers for the long-handled peels.
                • Updates for our latest pizza party. Didn't get a separate shot of the pizza making station in the foreground. The base is made from the left over framing members from the pavilion and the top is a nice sized 26" x 36" made of remnants from a prior butcher block counter job.
                  • Like the menu............
                    • Love the simple pegs to hang & display the pizza tools. Can't beat having a classy Il Forno entrance post & menu board. Well done!
                      Roseburg, Oregon
                      • Thanks Mike,
                        Cost update: Just dropped below $56 per pizza/loaf
                        • Hey Giovanni Rossi that is looking fantastic. I like the menu board and your il Forno sign. I may have to try setting up something like that next year. What did you make the menu board out of? Also did you have that metal sign made or was it prefabricated. Something like that might be cool for a treehouse Pizza sign.
                          Randy
                          • Hi RandyJ , thanks. The menu board is from an old piece of Masonite I've had lying around for about 30 yrs. Around the same time I milled a bunch of cherry for diploma and certificate frames and I had just enough left to frame the menu. My daughter sprayed the board with chalkboard paint and then added the text and artwork. I used the extra chain from the pavilion lights to fashion the hangers. The chains are anchored to the bottom of the frame bc it's got a little weight to it.
                            Daughter had the sign made through an Etsy site. They did a nice job. She played with the font size to get everything on the limited real estate. Some of the text is hard to show in a photo bc of the thickness of the metal.
                            It reads IL FORNO DELLA FAMIGLIA ROSSI (The Rossi family oven)
                            I can PM you the site if you're interested
                            • Hey Giovanni Rossi that would be awesome if you could pm me the website for the sign. I would love to get something like that. I was also taking a closer look at your roof structure and noticed you used the same bracket as I did. Looks to be OZCO I am super happy with mine. Probably cost me as much for the bracktery as the wood but oh well I didn't have to pay for any labor so that make it a moot point. It also seems to have made everything very solid. Once again it is looking fantastic.
                              Randy
                              • Finally got a pic of the new pizza prep station before our last party. The frame is made of remnants from the pavilion. Plus, it folds for storage.
                                Made 19 pizze and a little bread the next day.
