Hello Everyone,
Welcome to my second effort into building the best pizza oven possible! My first build is rather haphazardly chronicled here:
https://community.fornobravo.com/for...2-pompeii-oven
I'm in the very early stages of planning my next oven (read: we are planning on buying a house this Spring) but as I dusted off my old notes and spreadsheets I wanted to talk about the things that I would do differently the second time around.
So this first post is meant to be a list of lessons learned from my first building experience, both good and bad. I'm going to list them out in roughly my order of significance.
What about others, what are your lessons learned?
- BUILD THE OVEN! I built my original oven on the cheapest shoestring budget (both financial and time-wise) you can imagine for a busy father of four running his own business. There were significant compromises throughout the design and build process. The biggest factor in choosing the time to build was that my wife had graciously offered her support to the project after nearly 12 years of waiting and dreaming. It felt like now or never. Turns out, the oven was an almost overnight hit with our entire family. The versatility, fun, and utility of the oven took my wife from put-upon, but wonderful, supporter of her husband’s crazy oven obsession to small playful scuffles over whose turn it was to be the pizza slinger for the night. The kids love everything from pizza to breads, to steaks, to making perfect smores on the door landing (seriously, hang-outs and playdates have been planned around this feature). We all love it, and when we moved and started contemplating housing preferences, the outdoor kitchen feasibility of a house ranks up near the number of bedrooms for our kids in importance! So, if you are thinking about whether to build the over or not, not matter to compromises, build the oven!
- My biggest regret by far, was using the only (light duty) firebrick I was able to source at the time. It was a two-hour drive to purchase the brick after talking with sales folks who had little more information than “yep, it’s firebrick, it’s all we stock, and no we don’t know anything about it but it’s price and dimensions”, and no better options were to be found (they were out there, I just didn’t hunt hard enough). To be clear, the light duty nature of the brick’s thermal mass is perfectly acceptable for the needs of my family. It heats up fast, stays hot long enough for high temperature cooking and then retains enough heat for me to slow cook briskets and other meals over the next several days, I had no complaints about that aspect. However, the durability of the brick is terrible. I saw this with fear during the construction process, but it was even more clear after only a few months of use; the chipping and wear marks on the archway and floor of the oven were heartbreaking after putting in so much effort. When we left there were 1/4" groves where the door slid into place and chips all over the archway. The floor was also starting to lightly pit everywhere I cooked. This time around I have sourced (another long distance) medium duty firebrick to use on the archway and floor. I plan to use the same (this time locally available) light-duty firebrick for the dome, which encounters trivial wear and tear and is only 1/3 as costly as the medium duty brick. If I am going to put in all this work and heart, by golly I want the oven to last!
- Get the right masonry saw! Probably my biggest compromise after my ignorant brick choice, was using a woefully inadequate cheap table saw-type tile saw for the brick cutting. The blade was so short I had to flip them to finish cuts, and bevels of any sort were a painful and unsatisfactory experience that can only be called embarrassing. I knew it was the wrong choice, but it’s what I had, and the price was right. Like I said earlier, I have no regrets on building it when I did, but I plan to properly source a good (probably used) overhead masonry saw so that I can do all the proper bevels and angles I want without the crushing limitations of a tiny saw.
- I’m excited and delighted to prepare to build my next oven with tighter cuts for all the bricks. Thanks to the helpful work of others (like this discussion here), I plan to cut the bricks along both the “tilt” and “side” angle planes, hopefully creating a tight and self-locking brick dome with minimal use of mortar. My rough-and-ready first oven cooks just as well as any oven I’ve heard described here, so this decision isn’t about making better pizza, rather it’s about my wanting showcase my best craftsmanship. These last few years have been rough ones for me, but something I’ve taken from them is that I’m never happy with my rushed, half-ass efforts, when I knew I could do better; and I am excited to do better this time around!
- You can never have too much thermal insulation! For my first oven, I mis-calculated how much woven insulation I would need as I was trying to save money, and so the top of my oven had a measly 1” and some scraps to hold in the heat. Like I said, in practice I was still easily holding temps in the 200Fs several days after a firing, but my failure, and the resulting compensation with vermiculite has bugged me as a matter of principle ever since. Mk 2 Oven is getting 3” glorious inches around the entire oven, with carefully thought out insulating around the doorway and the inclusion of a thermal gap like UtahBeehiver describes here.
- I’m considering integrating an ash slot into my oven, right in front of, or under, the door jamb, as a combo thermal gap and ease of use feature. Using our oven regularly showed me the wisdom of a slick way to dispose of the ash rather than to rake it all out the front and inevitably all over everything else. I’m thinking a piece of lose stainless steel square tubing to bridge the gap on the oven floor (Like Russell uses in the above link), and a fabricated stainless steel “funnel” with a tray catch hanger I can integrate into my concrete slab pour. One simply would have to place a bucket or tray under the slab, pull out the loose piece of stainless-steel tubing covering the slot, and with a few quick rakes all the fine ash falls down the shoot and is neatly funneled into the bucket. Between my concrete skills (had to pay for college somehow!) and my brother in laws excellent plasma cutting and fabricating shop, I think we can come up with an excellent system to integrate into the build. However, I’d love to hear other’s solutions for an easy clean out system!
- Thermocouples! To be clear, a handheld infrared heat gun works just fine and was even fun for the kids and adults alike, but I think it would be nice to have several temperature readouts integrated into the oven. I’m thinking in the center of the floor, on the side, and at the top of the dome. I’m just techy and nerdy enough to want to go digital so I can capture and log the readings, but also pragmatic enough to just want a basic instrument that “just works” with zero hassle.
- A beautiful façade and finish for the oven and outdoor space. I never planned on doing anything fancy for our original oven, and it was a simple affair where I made a practical but unremarkable stucco dome for the oven and never minded the bare masonry CMUs for the stand. My wife always wanted it beautified, so this time around there will be more!
- A simple steel chimney instead of a brick-built one. This is more of a preference than an absolute. My brick laying skills are not amazing, and I didn’t enjoy the work of the brick chimney I made, I think I’ll go for a nice (easy to install) dura-vent one this time around, but that could change based on how the exterior design and decoration plans go.
- So many things were GOOD choices that I don’t regret, and I thought I would mention a few of them here:
- The 42” oven is an ideal size, big enough to run two or three pizzas at a time, I’m glad I went for the bigger one!
- A corner installation makes for an easy and accessible space for serving guests and staging meals with pans and trays such as grilling meats or roasting veggies. Maybe I’d opt for a stone countertop rather than concrete, as the outdoor concrete never feels clean enough to use for bare pizza work.
- Making my own fireclay mortar was easy and relatively fun (kids loved to help mix it) the mortar was strong and worked easier than I expected.
- Building the dome without forms was fun and allowed for better, cleaner work on the insider.
