27inch/70cm Pizzo oven build in Rotterdam/The Netherlands
  • 27inch/70cm Pizzo oven build in Rotterdam/The Netherlands
    Hi Everyone, I am new to the forum. I already checked out different sections of the forum to get some inspiration but also to got a lot of information on what and how to build my own pizza oven.
    I want to have the pizza oven for some cozy summer (and maybe even winter) evenings making pizza together with my wife and 2 daughters, for me enjoying heating the oven up and cooking together with the family. And of course also the occasional party or large group event. I won't be something I will do every night in summer and also for me it's important heating up time won't be too long. Therefore I am more looking to build a smaller size oven.
    When I moved to our new house, one of the thing I definately wanted, was a pizza oven in the garden, I preferably to build one myself. Because of circumstances at a certain point I didn't believe I would have the time and energy to build one myself, so I settled on looking for a ready build version. I was actually looking at something like this: Ambiënta Cinza Iso Pro 100 x 100 cm
    â
    So a 100x100cm outside size pizza oven with an internal size of 85cm x 70cm. For me the right size considering my garden plan. I would then build the plateau/stand myself, and just buy the pizza oven.
    Then circumstances changed a little bit, so I thought let's do it myself. And without research thought I would make something like the above link. Now after some research and found out, that the way this oven is constructed is not the best, with the air vent/pipe behind the door entrance. I found out especially after seeing this image on the Forno Bravo website and reading all the info:
    Click image for larger version  Name:	center_vent_open1-1024x798.jpg Views:	0 Size:	182.5 KB ID:	469051
    Am I right to think the oven in the link above is not the right way to go, or maybe not worth all the time it takes to build a pizza oven to end up with something just not right?
    I am continuing my research on this site, and look at all the incredible builds. I am an industrial designer, so the design/look of the oven would be very important to me. I will first "build" it in 3d and also think very well about the outer finish of the oven. I will try to post as much of the progress here in the forum.
    Greetings, Patrick
    If you are only interested in cooking pizza and want an oven that will heat up quickly, then you would be better off looking at a low thermal mass oven like an Ooni. The ovens most folk here build have a lot of thermal mass and in addition to cooking pizza are used to cook a range of foods by baking and roasting using the stored thermal heat. This is not possible with a lightweight table top oven. Also it is incorrect to assume that a smaller oven will heat up much quicker than a larger one. The heat up time for an oven also depends on the size of the fire which is dictated by the volume of the chamber rather than the internal diameter. A small oven with thick walls and floor will actually be slower to heat up than a large oven with the same wall and floor thickness. Fuel consumption which is also an important factor in design selection is related to chamber volume. A large oven will consume a lot of fuel and is unsuitable to cook 3 or 4 pizzas on a Friday night and owners of this oven type quickly learn that they're only suited to larger parties.
      Thanks david for the reply. I understand your explanation and maybe my message was a bit too focussed on the quick heat up time. It's not so important. There are a couple of other factors I didn't mention:
      1. I really like the look and appeal of a brick pizza oven, it would be a great addition to the outdoor space
      2. I would really really love to build one, I need a project like this ;-)
      3. I would like to also to use it for making bread (when the oven is already cooling) or maybe Tajines and maybe I find some other thing that would be great for making too
      4. I don't have much more space for a much larger oven. I am already looking into tweaking the size a bit. I already made the stand (foundation and concrete blocks are already there, partly plastered too), but I can cast an larger hearth then I originally planned.
      I really do not like the look of the Ooni. It has this really technical look and feel that has nothing to do with traditional pizza making. I want to stay far away from this.
      Currently already designing and getting all the details straight on the design. When I have the design more detailed I will definately post it here.
        Ok, if you are interested in multi use of your oven, then the hemisphere either brick or cast, over a firebrick floor employing a crossdraft design with the flue at the front of the chamber, is considered the best all round design, proved by thousands of years use. Regarding the footprint, you’ve gone about it backwards. The interior diameter should be decided on first, then decide on wall thickness of the inner chamber, thickness of insulation layers and outer shell (or enclosure), to arrive at final outer diameter which will determine the size of the required supporting slab. Consideration also needs to be given to the weight of the dome and floor (related to oven size), which will determine required strength and therefore thickness of the supporting slab.
        Hope this helps. I share your disdain of the desktop ovens in preference to the superior traditional historical design builds.
          Thanks David for your last tips. I researched all the topics involved with building my first pizza oven build, mostly researched on this forum, looked at other builds. Based on this I made the design. I used the Pompeii excel calculator to create the base setup and eventually made the whole design in 3d CAD and made some visuals to check the design. I may eventually decide on modifying the outer layer a bit, but for now I am happy with how I want it to look (let's see if I can come close to this ;-)). Eventually I decided on the following:
          - 80 cm internal diameter (so bigger then I initially planned)
          - internal Dome height roughly: 42 cm
          - Entrance width: 45cm
          - Entrance height: 26 cm
          - I will buy 22 x11 x 6 cm fire bricks, that I will cut to the desired size, 11cm brick dome thickness
          - Flue gallery depth: 23 cm
          - Flue diameter: 125mm
          - I will cast the flue transition insitu just like David did in this build: https://community.fornobravo.com/for...nic#post435723
          - I will make the outer layer (render?), so it will be a nice full hemisphere look with a soft transition to the flue pipe
          I actually already build the stand from concrete blocks and put a plastered the outside with a cement base outdoor layer. I still need to cast the top.
          I now thought I need 2 layers of isolation blankets, so that will be 50mm thickness (one layer is 25mm). Is this necessary or is this overkill?
          For the layer of vermiculite I thought it would be around 3 cm thickness, is this realistic?
          Any feedback or tips are welcome, thanks!
          Finish your oven against the weather, and to look good -- even though you are already using it.
            You have a pretty good plan and obviously well researched. With a 6 cm thick floor and 11cm thick walls you have a lot of thermal mass for a small oven. The thickness difference also leads to some imbalance between floor and dome. Cast builds can get away quite successfully with 50mm walls (large cast ovens over 1m internal diameter often have 75mm thick domes). For brick builds which are separate unit construction, history confirms that any brick construction should be no less than 100mm thick). Eg The structural integrity of brick walls for homes or even gardens, is compromised if house bricks are laid on edge (3” or 75mm). A dome achieves enormous strength because of its form, but ovens and kilns have the additional problem of uneven thermal expansion which can compromise their structural integrity. There have been documented brick build failures on this forum that have attempted domes out of splits (2”). What this all means is that your 110 mm thick dome has quite a lot more thickness so there won’t be a structural problem, but it will take considerably longer to get to pizza temps and use correspondingly more fuel. The upside is that it can store a lot more heat and hold given temperatures longer. This will mean that you won’t be firing the oven much to cook just 3 pizzas. A lot depends on how you want to use your oven, but if it were me I’d be looking for some firebricks, for the dome, that were more like the standard house brick dimensions. Cutting 6cm thick bricks for the dome would be a lot more
            cutting and laying work than the standard half brick method.
              Thanks for the reply. I have been looking around for suppliers of these firebricks, and in the Netherlands I find the max thickness of these bricks of 6 cm (And most are around 220x110 mm). Probably buying them here:
              So what is the standard half brick method you are talking about? If I look in the FB plans, I see they are using 9"x4.5" bricks (so rougly the same rectangular shape as I will be using), and they are 2 1/2 inch thick (6.35cm), so that's rougly the same size, right? Or maybe I am misunderstanding.
              So I was thinking to make a cutting jig, and use half bricks for the dome. I wanted to use a jig like in this post (from the pompeii excel calculator): https://community.fornobravo.com/for...-table?t=16780
              I will put a layer of FB board of 5cm below the cooking floor.
              Attached already some photos of the foundation and stand I already made this past summer, I didn't have much space, so eventually I will have the work top overhang a bit on all sides. I also already plastered the stand (no photos yet), I used a lot of second hand concrete blocks, so they don't look so nice without a nice layer of plastering/cement.
                Bricks particularly firebricks, come in lots of different sizes. For an oven medium duty bricks are best. Low duty are a bit too soft for good durability and longevity. High duty are very hard to cut and eat expensive diamond blades. Traditional Imperial bricks are 9” x 4” x3” so your 6cm thick bricks are well short of 3”
                I fully understand that you have to just get what’s available, so with the bricks cut in half you will end up with a 110 mm thick dome and a 60mm thick floor. Not exactly the best because the floor’s a bit thin and the dome a bit thick. You could lay the half bricks either flat or on edge. If you lay them flat you’ll only rise 6cm for each course. On edge you’ll rise 110mm. My drawings should explain what I mean. With a thin floor you’d be better to have two layers of calsil insulating board.It comes in either 40mm or 50mm usually.
                    Sorry, I’m having trouble with my desktop and can’t post the drawings via my phone.
                      Because of bad weather, haven't been really able to make progress. I am working towards casting the concrete slab. In regards to that, I was wondering if I could integrate the insulation underneath the hearth into the concrete slab, this would reduce the height of the oven entrance. For example integrating FB board into the concrete or a vermiculite concrete mixture (see attached renders to explain the idea).Would this be possible or a very bad idea?
