Aussie Mobile base oven
  • toyota08
    • Jul 2008
    • 59
    #31
    Re: Aussie Mobile base oven
    G"day Damon the only thing i would do to make the bricks more stable for a mobile towable oven i would run metal straps over the dome attatched to allthread rod passing through the base and fasten the dome down then cover with ceramic blanket.
    just make sure your trailer has soft springs and shockers fitted,sounds like a project amagine the cost to tow the bugger!!!!
    cheers Peter
    • Bacterium
      • Apr 2007
      • 560
      #32
      yeah I think towing would be an issue for me
      Damon
      Build #1
      Build #2 (Current)
        Yeah the towing is a pain. Especially when you forget you're towing it and you hit a speed bump !
        • toyota08
          • Jul 2008
          • 59
          #34
          Hi all ive made up a door i plaigerised on from this site
          $120.00 au for the 5mm glass
          cheers Peter
          • BRIFRO
            • Sep 2008
            • 21
            #35
            Nice looking door. What did you use to get the silver color on the frame?
            • staestc
              • Oct 2008
              • 256
              #36
              Wow! Very cool door! May I ask if you have to clean it much?
              Travis
              TravisNTexas
              • toyota08
                • Jul 2008
                • 59
                #37
                Hi Travis i haven't fired it with the door on yet may get to this sunday morning
                i will post the results.Brifro i used aluminium hi temp auto paint mate.
                Cheers Peter
                • toyota08
                  • Jul 2008
                  • 59
                  #38
                  Hi all fired the oven sunday night 1hr up to temp let settle cooked up beer can chicken
                  door worked a treat exellent draft it was sooted up after a hour but you could still see through it,best part you can check the fire at a glance as i was doing some chores around the garden.
                  Cheers Peter
                  • toyota08
                    • Jul 2008
                    • 59
                    #39
                    Re: Aussie Mobile base oven finished
                    Hi all thanks to you all my oven is finally finished,sorry i had no picks of the expansion joint i fitted between the dome and the chimney mount as the camera
                    was dead at the time.anyhow after i finished the expansion joint i coated
                    the dome with 3 coats of flexible pond liner from Bondall,i then painted the
                    whole oven with dulux paint on render.Im currantly getting a carport come pergola fitted so the oven will have proper home once fitted i will post the pic's
                    cheers and thanks
                    Peter
                      Hi,
                      Is your oven designed to fit on a trailer or do you just want to wheel it around your yard to cook in a different spot each week ?
                      • Frances
                        • Aug 2007
                        • 2186
                        #41
                        I love the way that has turned out!
                        Its got a really cool elegant shape, as it it had been carved out of a single piece of stone or something...
                        • toyota08
                          • Jul 2008
                          • 59
                          #42
                          G'day David the idea was to be able to build it in the shed and yes be able to
                          change its position on the patio if we have to in the future.
                          But its been good being able to face the front out of the prevailing south wind down here.It take 2 off us to move the bugger it now weights about 500kilos.
                          cheers mate Peter
                          P.S thanks frances my wife and i think your mosaic looks awesome.
                            great job. I like your attention to detail.
                            • nodoubt68
                              • Oct 2008
                              • 60
                              #44
                              Love it Peter !
                              How proud you must be, to be able to wheel your wicked oven out to use. Very impressive and unique. Thanks for showing us your build..
                              Cheers Lee
                              • toyota08
                                • Jul 2008
                                • 59
                                #45
                                Thanks for the kind words everyone i will hopefully be cooking Christmas dinner in the oven.
                                my veranda arrives friday and i have ordered 2 elbows and 2 1.5 metre lengths of flue
                                pipe.i will be a busy boy.
                                i will update with photos as i go.
                                cheers Peter
