Mark's WFO
  • Les
    • Sep 2005
    • 2945
    #181
    Re: Mark's WFO
    Mark,
    On my thread, page 11, post #90. It didn't work for me. The lath flexes and the mortar drops right through. I ended up using chicken wire and slopping the vermiculite through it. It's quite fun - I encourage you to give it a try.
    Les...
    • exceloven
      • Aug 2008
      • 279
      #182
      Re: Mark's WFO
      Its been awhile since I got anything done on my oven but I jumped back in today. I got some help and we fought intermittent downpours. I imagine Dino did also.
      I took the arch form out after two hours. Confident or stupid? Probably a little of both. I was worried about the clean-up. As it turned out I'm glad I did. Hopefully next weekend I'll get the brick work done.
      Mark
      • Les
        • Sep 2005
        • 2945
        #183
        Re: Mark's WFO
        SWEET! You have it on the run.
        Les...
        • exceloven
          • Aug 2008
          • 279
          #184
          Re: Mark's WFO
          Thanks Les,
          I had my laptop under cover with your pix up. I guess that's obvious though, at least to you. It really changed the whole look. I love it!
          Mark
          • bbell
            • Oct 2008
            • 195
            #185
            Re: Mark's WFO
            Mark, looks great. I might have to go find some used red bricks!
            Bill
            Oven Build: https://goo.gl/photos/rN6FhFSS2jzwfQuB7
            Oven cooking: https://photos.app.goo.gl/1vmPg7XXSbMwhdnD6
            • glennb
              • Oct 2008
              • 62
              #186
              Re: Mark's WFO
              Mark
              I removed my forms for both my arches straight away as well. I figure that I want to know if it's going to fall down now, rather than half way through a pizza night. Luckily everything stayed in place.
              Your WFO looks great too.
              • dbhansen
                • Jun 2007
                • 566
                #187
                Re: Mark's WFO
                Looks great, Mark! I'm hoping to do something similar with the face of mine.
                Picasa web album
                Oven-building thread
                • Dino_Pizza
                  • Feb 2008
                  • 1036
                  #188
                  Re: Mark's WFO
                  Nice brick work Mark. Very classic looking. So you've been working in the rain? It's slowed me down too. I was cutting arch wall bricks under my covered patio during a downpour.
                  Hey, the used bricks look really sharp! Will the dome behind it be stucco-igloo and the facade the square/brick ?
                  Take care, Dino
                  My Oven Costs Spreadsheet
                  My Oven Thread
                  • exceloven
                    • Aug 2008
                    • 279
                    #189
                    Re: Mark's WFO
                    Thanks All,
                    Dino, for the dome I am planning on just using stucco. I am going to look for a inexpensive mosaic tile that is very neutral in color. But either way I am keeping the dome look.
                    Mark
                    • Ellie
                      • Dec 2008
                      • 94
                      #190
                      Re: Mark's WFO
                      It really is coming along. Almost done. It looks like three or so of us will be done at about the same time. I give mine two to three days. How about you?
                      • exceloven
                        • Aug 2008
                        • 279
                        #191
                        Re: Mark's WFO
                        Ellie, Considering its been two months to get this far, by the time everything is done it will most likely be two more months. Unfortunately this is a part time project. I have already started using the oven though and am thoroughly enjoying it. For the size of your project I think you hold the record for time of completion. It looks great.
                        Mark
                        • Ellie
                          • Dec 2008
                          • 94
                          #192
                          Re: Mark's WFO
                          Well, I think you have done splendidly. I cheated.... have someone doing it for me. I love to do projects, but this one is out of my league...
                          Ellie
                          • exceloven
                            • Aug 2008
                            • 279
                            #193
                            Re: Mark's WFO
                            There has been alot of talk the last few days about the vermiculite/cement insulation layer. My question is.... does it have to be wet, does it make a difference insulation wise if you put it in dry?
                            Mark
                            • gjbingham
                              • Sep 2007
                              • 2021
                              #194
                              Re: Mark's WFO
                              Dry is fine for the layer outside the dome itself, if you have a stucture to contain it, (read: walls/roof). You will not be able to keep it where you place it without concrete, if you are using an igloo style finish.
                              Dave tried it without down in Texas. His vermiculte (inside his wire mesh retainer) all sagged to the sides of the dome.
                              GJBingham
                              • Frances
                                • Aug 2007
                                • 2186
                                #195
                                Re: Mark's WFO
                                I've got a dry vermiculite layer on my igloo style oven and I think Wiley did the same - you just have to add another mortar/mesh/rebar layer to keep the vermiculite in. It can be a bit fiddly, but it works.
                                Dave's would have worked also, except he paused in his project just before adding the final layer of mortar over the wire mesh...
                                As for insulation, I don't know which is better. I did mine that way because I needed to keep the rockwool insulating blanket dry.
