Mark's WFO
  • berryst
    • Jun 2008
    • 184
    #196
    Re: Mark's WFO
    I did both. I made the lightest concrete mix I could. Then after I had gooped it the best I could I used sheet metal (old galvanized roofing) to contain the pour. I poured in the remaining bags of vermiculite over the whole works then covered the whole show with dirt ...Seems like I used about ten large bags or so.
    sigpic
    • exceloven
      • Aug 2008
      • 279
      #197
      Re: Mark's WFO
      I was able to beat the rain and get some more done today. I built the herringbone section on the ground during the week and then just set it in place today. Then built around it. I ran out of bricks for the arch, but it was a full day anyway, there's always next weekend.
      Mark
      • Modthyrth
        • Mar 2008
        • 359
        #198
        Re: Mark's WFO
        Absolutely beautiful! I'm very impressed with your workmanship and speed.
        Nikki
        • Les
          • Sep 2005
          • 2945
          #199
          Re: Mark's WFO
          It's going to be a thing of beauty! Fun to watch.
          Les...
          • exceloven
            • Aug 2008
            • 279
            #200
            Re: Mark's WFO
            Wow thanks Les, that means alot coming from the master!
            Mark
            • mfiore
              • Oct 2007
              • 919
              #201
              Re: Mark's WFO
              Mark. The herringbone section looks great! Inspirational.
              Mike - Saginaw, MI
              Picasa Web Album
              My oven build thread
              • Dino_Pizza
                • Feb 2008
                • 1036
                #202
                Re: Mark's WFO
                That looks GREAT Mark! The recessed herringbone section and chimney top detail add a lot of character. I love watching your build. Lots of great ideas.
                Dino
                My Oven Costs Spreadsheet
                My Oven Thread
                • exceloven
                  • Aug 2008
                  • 279
                  #203
                  Re: Mark's WFO
                  Thanks Dino, Most of my ideas have been found on the forum. I just mix and match what works for my taste. By the way your is looking very clean! I'm sure you will end up with a round dome.
                  Mark
                  • exceloven
                    • Aug 2008
                    • 279
                    #204
                    Re: Mark's WFO
                    Its been over a month but I finally got a little done on the oven today. I got the scratch coat on the dome and filled it with vermiculite. I'm planning on cutting some sort of form to use as a screed to get the dome somewhat round, or at least consistently unround. The chimney blocks most of it anyway. Since I haven't been able to work on mine I have been living vicariously through all of your builds.
                    Even though it isn't done I have been using it. Everything I have cooked in it has been amazing. Its more than worth all the effort and then some!
                    Mark
                    • Les
                      • Sep 2005
                      • 2945
                      #205
                      Re: Mark's WFO
                      Looking great mark! Getting it round is a bitch. I kept adding the stucco a few times, then said good enough. It's hard to get it perfect. Sometimes I walk out, and in certain lighting, I say damn - didn't see that spot. At the end of the day, it changes nothing in regard to the quality of food.
                      Les...
                      • exceloven
                        • Aug 2008
                        • 279
                        #206
                        Re: Mark's WFO
                        Thanks a lot Les. I'm like you, I will always notice those little mistakes, that fortunately no one else will ever notice. None of those mistakes will make the pizza any less delicious.
                        Mark
                        • bbell
                          • Oct 2008
                          • 195
                          #207
                          Re: Mark's WFO
                          I agree Mark. The pizza remains the same... delicious! Your build looks great.
                          Bill
                          Bill
                          Oven Build: https://goo.gl/photos/rN6FhFSS2jzwfQuB7
                          Oven cooking: https://photos.app.goo.gl/1vmPg7XXSbMwhdnD6
                          • christo
                            • Feb 2006
                            • 913
                            #208
                            Re: Mark's WFO
                            I think it looks just great!
                            Based on the level of workmanship we've seen so far from you, I have a feeling that there will be others coveting the outer dome of your project as well.
                            Enjoy! How many chances do we get to make semi-perfect concrete spheres freehand?
                            Christo
                            My oven progress -
                            sigpic
                            • Calabrese
                              • Feb 2009
                              • 48
                              #209
                              Re: Mark's WFO
                              Hi, Mark my name is Joe and I've only been reading this forum for a short while but I believe you've set a new standard. You're oven build is amazing and your workmanship is that of a craftsmen. I want to thank you for sharing your oven build with us, it has been inspirational as well as informitible. I, like others on this forum have never layed a brick in our lives and FORNO BROVO has made a project this intimadating very achievable. What I love about this forum is no matter how simple or complicated the build the amount of incouragment and support is outstanding I really dought there have been any failures. People like Les, Christo, Bandransco, james and dmun have all given their time and knowledge all in the the name in creating the ultimate goal THE PERFECT PIZZA. Congratulations on your oven and hope you stay on and help us new builders. REGARDS JOE
                              • Duke
                                • Jan 2009
                                • 1
                                #210
                                Re: Mark's WFO
                                Mark-
                                I was wondering where you found the firebricks? I also live in the San Diego area.
