Re: Dino's 42" Pizza Oven Starts
Thanks Daren, I used 1.5" exterior wood to steel screws. I quickly pre-drilled a shallow recess to make sure the screws heads sank in a little. Then putty and sand it. I used the same screws at the edges of the fascia (wood to wood) and at the top edge (fascia to roof plywood) so everything seems tight and square.
If it looks good, blame the straight boards and fresh putty, not me
-Dino
