Ellie's WFO as it it built
  • #46
    Re: Ellie's WFO as it it built
    If you look real closely, you can see my hen, Victoria Elizabeth making sure Dale does it right !
    Just had to share...
    Ellie
    • #47
      Cyclone Ellie has delivered us about a metre of rain. Highway cut off both north and south of us. We haven't seen the sun for about two and a half weeks. I'm firing my oven now with the last of my dry wood to try and dry it out. Pool is overflowing for about the tenth time. I think my next project is going to be a very large wooden boat, but I'll have to hurry.
      • #48
        I'm so sorry.... hope you dry out soon. Dang, I had hoped my namesake would have been mild.
        E
        • #49
          Actually the cyclone part of it was really mild, but we've been left with a massive rain depression. Seems the planet is full of weather extremes. At least a WFO uses renewable fuel which recycles carbon already in the system.
          • #50
            Ellie, I don't think Dale has anything to worry about. I think it is best of Victoria Elizabeth heads for the hills when you bring out the BBQ sause and beer cans!
            I'm enjoying watching your WFO progress.
            Cheers,
            • #51
              Whew! Finally got the insulation on. This was tough. It looks good though.
              Ellie
              • #52
                Looks great Ellie!
                How thick is the blanket layer??
                Is Victoria a Maran?
                My 2nd Build:
                Is here
                • #53
                  Thanks, the layer is 3" thick, I think. We just stripped the back off of regular insulation. The hard part was attaching the wire to the dome. He had to put screws in to hold it together. They did not go in very far, though.
                  Victoria Elizabeth is my only cross. She is an Ameracauna crossed with a barred rock. She is the only chicken who jumps the fence and comes in the back yard. And.. she puts herself back in the chicken yard when she has checked everything out!!
                  Ellie
                  • #54
                    Hi Ellie did you place regular house insulation on the dome? will that work?
                    • #55
                      From what I've read, yes it works as long as you take the backing off. It is over a coating of fireclay and cement.
                      Ellie
                      • #56
                        Ellie, it looks great!
                        Bill
                        Oven Build: https://goo.gl/photos/rN6FhFSS2jzwfQuB7
                        Oven cooking: https://photos.app.goo.gl/1vmPg7XXSbMwhdnD6
                        • #57
                          We eagerly await results of the house insulation experiment: you might want to hold off on fabulous surface treatments before you find out if the house insulation will hold heat and keep the exterior cool enough not to be a hazard.
                          • #58
                            Good point dmun. Has anybody measured the temps on the outside surface of the dome bricks while the interior is 900 or so degrees? I wonder weather regular home insulation, sans paper, can withstand the exterior dome heat without eventually looking like the singed hairs on the back of my hands after a night of making pizza.
                            GJBingham
                            • #59
                              More fool you for getting your hands in what is known as a very hot oven eh!
                              Rastys
                              If you don't succeed the first time, try again and again until you get it right!
                              • #60
                                Ellie, what did you read that said it was ok? I'm not so sure. Rockwool (which I think some people have used) isn't as good an insulator as insulating blanket, but it's ok. Rockwool isn't the same as the pink stuff, though. It would be a pity to get it all done and discover that it isn't what you need.
                                Can you leave it where it is for a while, let it dry out a bit, cure it and test it? That way if it isn't enough, or if it melts or something, you can fix it without tearing your hair out.
                                Elizabeth
