Oven Floor Temperatures
  • Roadkyng
    • Jan 2009
    • 77
    Question for thos who have thermocouples in their floors:
    What are the highest temps you see?
    I have been researching Cal-Sil Board sources and found a site that sells 2" thick board for $3.56 sqft. Looking at the specs (ASTM C 533, Type I) it shows a heat rating of 1200 degrees F (649 degrees C).
    The Cal-Sil Board sold in the FB store states a heat rating of 1200 degrees C (over 2400 F). (possible typo?)
    Now I suppose there are different grades or specifications of Cal-Sil Board. My question is, what floor temps are likely to be seen? ie if 1200 degrees F is completely adequate I can't see paying 3 times the price for board that will never come close to the temp rating possible.
  • exceloven
    • Aug 2008
    • 279
    Re: Oven Floor Temperatures
    The highest I've sen with my laser was right around 920.
    Mark
    • CanuckJim
      • Jan 2006
      • 1480
      The highest I've seen from the thermocouple in the hearth bricks was 1030.
      Jim
      • mfiore
        • Oct 2007
        • 919
        Roadkyng, I can't comment on your question, but I love the Avatar!
        Mike - Saginaw, MI
        Picasa Web Album
        My oven build thread
        • wlively
          • May 2005
          • 384
          I have standard floor (flat bricks) and TC's with center of brick measurement. There is no way you are going to overheat the floor insulation on a normal pizza firing. The highest temps I have recorded for the floor mass was approx 450 degF. The floor is the slowest to rise in temp as the only way for it to receive heat is conduction of the coals and has the highest cooling load as the incoming cold air is constantly running over it. I don't see a problem with 1200 deg limit unless you are going to fire daily.
          See added post under original topic.
          Wade Lively
          • Roadkyng
            • Jan 2009
            • 77
            Thanks!. My favorite strip
            • Roadkyng
              • Jan 2009
              • 77
              Since this will be a personal overn I won't be firing every day or continuously. So I should be fine.
              Nice RV by the way
