Question for thos who have thermocouples in their floors:
What are the highest temps you see?
I have been researching Cal-Sil Board sources and found a site that sells 2" thick board for $3.56 sqft. Looking at the specs (ASTM C 533, Type I) it shows a heat rating of 1200 degrees F (649 degrees C).
The Cal-Sil Board sold in the FB store states a heat rating of 1200 degrees C (over 2400 F). (possible typo?)
Now I suppose there are different grades or specifications of Cal-Sil Board. My question is, what floor temps are likely to be seen? ie if 1200 degrees F is completely adequate I can't see paying 3 times the price for board that will never come close to the temp rating possible.
