Perry's Pizza Oven
  • KINGRIUS
    • Aug 2009
    • 113
    #16
    Re: Perry's Pizza Oven
    Perry, I love your oven. Really cool. Thanks for all your documentation. I especially like the pic of you taken from inside the oven. Whoever you got to crawl in the there to take that for you must me a very small person! lol
    I have been tempted to construct a brick guide like you and others have used, but since I have decided to construct a low dome (36" dia., 14" H) mainly for better pizza, it puts my dome radius sub-floor and couldn't use one. Thanks again for sharing your project!
    Almost forgot to mention how I'm going to steal your angle cutting idea on your soldier course.
    -Darius
    • PerryPizza
      • Sep 2008
      • 90
      #17
      Thank you for the comments Darius, really glad you like it.
      You can use a guide if you are able to have an adjustable offset arm - my oven is small and has the lower Neapolitan dome you refer to, the radius of the dome works out 15cm under the oven floor - if you have look carefully at this picture of the life-size drawing of the cross section of the oven you'll see the radial lines I actually used to set the guide arm for each chain of bricks. It's a bit of hassle compared to a centrally fixed guide but it does work... let me know if that doesn't make sense and I'll try and illustrate it better.
      Thanks again!
      My rustic oven;
      http://www.fornobravo.com/forum/f8/p...oven-6770.html
      sigpic
      • KINGRIUS
        • Aug 2009
        • 113
        #18
        Yes it does make sense! My radius works out to be 14cm beneath floor. Now that I'm studying your tool closer, I do think I will be able to use this! I especially like it because its made out of materials/tools I already have. Thank you!
        • PerryPizza
          • Sep 2008
          • 90
          #19
          Cool!
          Here's a rough diagram showing the principal, your guide will need to slide and tilt, but I would recommend something slightly more sturdy than the guide I made (I ended up using 3 clamps, and those clamps get right in the way!). I also used shims to help whilst the mortar set.
          Hope this helps
          ps using an adjustable guide like this allows any shape of dome you like
          My rustic oven;
          sigpic
          • Mitchamus
            • Aug 2008
            • 389
            #20
            Awesome!!!
            My 2nd Build:
            Is here
            • PerryPizza
              • Sep 2008
              • 90
              #21
              Keeping with the rustic/ reclaimed theme, the door was made from an old oak floorboard I found, cut up and screwed together to for a 'plug'
              My rustic oven;
              sigpic
              • Fish Wheels
                • Sep 2009
                • 70
                #22
                From your first picture I wondered how you'd get a oven in there! Congratulations you pulled it off
                I would have a shot at the answer, if I had the appropriate question.
                • Roadkyng
                  • Jan 2009
                  • 77
                  #23
                  Originally posted by PerryPizza
                  Thanks Jamie, I know it isn't in the same league as some of the precision ovens on the forum, but it fits in the surroundings well and, more importantly, it cooks pizzas which is all I ever wanted!
                  One of the neatest ovens I have seen on this site. The coolest thing is, it looks identical to the ovens that inspired James and company to do this in the first place. Fits right in with the Pompei Oven theme.
                  Bravo.
                  • PerryPizza
                    • Sep 2008
                    • 90
                    #24
                    Bravo.
                    Thank you Roadkyng, though I can't imagine it will be around in a few hundred years like those original ones!! Still gives me immense pleasure every time I fire it - like I'm about to right now!
                    My rustic oven;
                    sigpic
