The roof slope? Flat as can be...I put a rubber pond liner under the roofing material just to be sure it was watertight...
Drake
Hi Drake. I was browsing the forum for ideas and came across your oven. Amazing! I am also planning a flat roof and was woping I could ask you a question: Did you glue the pond liner down with anything, and also, did you tape the seams at the corners which overlap the vertical walls? Thanks so much!
