Re: Pizza Bob's 42" Build
I used 45 degree elbows and the chimney drafts well.
I really want to vent out the middle of the hipped roof as shown in the attached picture.
. My wife is pregnant and craving pizza all the time so we have plenty of pizza boxes. I eventually moved onto small sticks and increased temperatures over the course of the week until I got to about 700 degrees. I couldn't let the fires go to waste so we took tomatoes and basil with EVOO from the garden and roasted them on a pan. They were pretty tasty but I'm not sure if I can give all the credit to the oven. How bad can garden tomatoes and basil really be even without a brick oven?? We also roasted some eggplant from the garden which came out really good too.
Once the blankets are in place I have a hipped-roof sheetmetal studded cement board enclosure built around everything. The space between the cement board and blankets will then be filled in with loose vermiculite. I don't plan on putting any cladding around the dome (under the blanket). The way I look at it is the hearth floor is just under 2.5" thick with plenty of insulation underneath it and the heat will be retained just fine here. The dome bricks are 4.5" thick so why do I need a cladding of one inch?? I hope it doesn't come back to bite me in the *ss but I don't think it will. Besides, my curing fires are just about done and if I add the cladding then I'll need to start the curing fires all over again.
I never imagined the veneer stone would be that much! So their engineering department reviewed the drawings I sent them and they ran some calculations for me and determined I should use the 18 gauge studs. These studs are .0451" thick. The steel studs are from Marino\WARE - metal framing systems, lightweight steel framing for commercial and residential buildings.. Their technical services group was great! They replied immediately with an answer after I sent them my drawings. I attached a JPG for my stone veneer and the structural catalog from Marino-Ware can be found at this link:
