Re: Pizza Bob's 42" Build
Hello Dave T.,
I am just south of Waterbury in Oxford - small world! I thought of using the Super-Isol but went with 2.5" thick FoamGlas encapsulated under 3.5" of vermicrete. I really believe heat loss through the floor is a huge problem for cooking multiple pizzas.
Dave W.,
Thanks and welcome back yourself! Hurry up and finish the honey-do-list so you can finish off that oven!
I'm looking forward to seeing more pix...
Dino,
I completed 8 courses (if you count the soldier course). I have about four - five more courses to go! Then I need to do the inner arch and flue transition and then the outer arch. I apologize for never answering your Bernoulli equation question...The software can determine effects of a tapered flue and provide numbers for acceleration, pressure, temperature and velocity changes. It really is a great program and I will use it to finalize the flue design. I'll share results if you're interested.
Ciao,
Bob
Hello Dave T.,
Dave W.,
I'm looking forward to seeing more pix...Dino,
Ciao,
Bob
. I cut the bricks and will probably mortar them in this week. Also...I haven't used my indispensible tool since course three but think I might need some type of form for these last few courses. I haven't used or needed a form because I mix the HeatStop50 to a consistency that requires me to hold the brick in place for approximately 30 seconds and then move on to the next.
I dry stack on top of this height gage on every course and it seems as if I should be alight with the spacing shown. What do you think?
I noticed a crack in the mortar joint between course #4 and course #5! It's a very fine crack along the top of row #4 brick and bottom of row #5 brick. It runs along the circumference for a couple bricks. I haven't done any curing fires yet and a crack already??? I tried to keep a minimal mortar joint, as you can see in the picture, between top and bottom of bricks. I was so disheartened when I saw this crack! I think it might have happened over the winter when temps hovered around zero degress for weeks! I might have had some water in the masonry and it froze. What else would it be??? I'm not exactly sure what to do now but I don't believe I have many options...
