Pizza Bob's 42" Build
  • Dino_Pizza
    • Feb 2008
    • 1036
    #61
    Re: Pizza Bob's 42" Build
    Excellent work Bob! I'm impressed you compounded on the 1st row. It's hard work but I love seeing the same width up and down on those vertical mortar joints. Humidity is great for the mortar, sorry you have to be in too Dino
    My Oven Costs Spreadsheet
    My Oven Thread
    • mrgweeto
      • Oct 2008
      • 173
      #62
      Rodney,
      You're spot on when you said "my time" projects. Our wives wonder why we are so infatuated with the build especially when they see how tired and sweaty we are after 4+ hours of work after we get out of work. We tell them that this is for us. The difference is that we don't have to do it but want to do it. Not like redoing a bathroom (my next project). We start our enclosure today or tommorrw. I spent a couple of hours makeing a decorative flue topper which I will post tomorrow (forgot to take the camera home from work). Came out pretty good if I do say so myself.
      Bob,
      Nice clean looking work. We are going to have to change your name from Pizza Bob to Rembrandt Bob.
      G
      • pizza_bob
        • Apr 2008
        • 181
        #63
        Originally posted by mrgweeto
        Bob,
        G
        G,
        Thanks. I like that - Rembrandt Bob. It's gonna take me longer than it has already taken me if I decide to taper all the dome bricks. Lets see when my patience runs out.
        I had a question about the skim-coat on the dome exterior. I started applying it to the fist couple courses but I'm wondering what its purpose is. Any functional reason?
        ~Bob
        My Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
        If you fail to plan, you plan to fail!
        • Rodneyf
          • 148
          #64
          There is no reason at all for the "skim coat" and I only used the left over mortar each time to give the dome a uniform looking finish.
          • stevensadler
            • Aug 2009
            • 2
            #65
            Bob
            is it possible to get hold of a copy of your plans, in pdf, autocad wanting to start a oven, but not sure where to, if you could that would be fantastic. send to stevensadler@aol.com
            I probably should have started my build thread earlier but better late than never...
            I'm building a 42" Pompeii style oven. I'm a mechanical/design engineer (mostly medical instruments for surgery) and have never "buttered" a brick before. But I am Italian and must have it in my blood. I have recently become a first time father with the birth of my son Luciano. I'm a triplet (three boys) and 6'6" tall - so yes my cooking hearth will be approximately 50"
            I have been obsessed with creating this design in my CAD software (SolidWorks) before I do anything outside. I am pouring my insulation layer today so I've been trying to stay one-step ahead on the computer design. I started laying-out the vent landing area and was looking for some advice.
            I have been viewing exceloven's images to get sizes of certain areas of the oven by counting bricks. Has there been any advantages or disadvantages of having a 13.5 vent landing depth? The images below show a that depth and a vent opening that is 16.5" x 4.5". Will a vent opening of this size create too much ofa draw and contribute to problems retaining heat?
            I thought exceloven's method of creating the "hard stop" for a door was great! I think I laid it out the same way. It ends-up being a 1" reveal that is created by offsetting the inner arch - very clean looking.
            My hearth "sandwich" is 3.5" structural concrete w/rebar, 2.5" Foamglas under the oven and vent landing area, 4.5" of vermicrete at a ratio of 4:1 to provide some thermal mass and then the cooking floor bricks.
            I look forward to the rest of this build and discussions with all in the group. I would never had been able to do this without this group.
            Thank you in advance!
            ~Bob[/QUOTE]
            • Dino_Pizza
              • Feb 2008
              • 1036
              #66
              Hi Bob (and Rodney for this post),
              Just to be sure everyone is on the same page, if by "skim coat" you mean the high-heat mortar you smear on the outside of the dome bricks while you build it, then that "cladding" is part of the ovens "mass". You have to decide how much extra mass you want just like you decide on the oven width and height. I wanted a 1/4" of extra mass added around the dome to 1) add mass that heats up and releases the btu's just like the fire brick, 2) gives you the feeling of somehow adding some structural integrity to the dome although it really doesn't but I suspect it might make the joints stronger if you add it to the outside of that joint while it's still moist. And 3) unfortunately it shows all the hairline cracks you'll get when you 1st fire up the oven but that's OK.
              Some have added 1/2" of extra cladding, others barely a skim coat. Your oven will heat up faster without it, but with it, you retain more heat for longer cooking times and works better for bread baking.
              You can add the cladding while you work on the rings to use up the extra mortar or go back after you're done make sure you have an even amount.
              Happy WFO building, -Dino
              My Oven Thread
              • dinoforno
                • Jun 2009
                • 22
                #67
                Bob,
                I am just curious why did you chose to add the vermiculite layer on top of the Foamglass?
                If you have 2.5" and you look at some of the data on FoamGlass wouldn't it just be overkill.
                • pizza_bob
                  • Apr 2008
                  • 181
                  #68
                  dinoforno,
                  I'm not sure if my reasons for adding 2.5" of vermiculite over the 2.5" of Foamglas are correct but...
                  Reason #1: Foamglas data does show it to be a super insulator and at first I was going to use 4" Foamglas as opposed to the 2.5". But I thought I would need more thermal mass under my hearth bricks. I went with a 5:1 ratio of vermiculite/Portland thinking that slightly more cement would give me some thermal mass that I am looking for and then the vermiculite and Foamglas will give me the insulation I wanted. I don't think you can "overkill" insulation anywhere on these ovens. If you can fit it and afford it the extra insulation will always help retain heat. I really don't want to keep "recharging" the cooking floor after every pizza. I was told by an oven builder who uses the Foamglas regularly to use 4" of Foamglas and pour 4" of cement over the Foamglas for thermal mass. I thought my heat-up times would take too long so didn't do that - I hope I don't come to regret that when my oven doesn't retain heat well.
                  Reason #2: Foamglas is very abrasive or gritty when rubbed against another piece of Foamglas or against bricks or concrete. The Foamglas blocks produce powdered or fine particles of glass when this happens. I did not want my hearth bricks resting directly on the Foamglas and risk glass particles coming up through gaps between bricks. I used fireclay/sand/water bed to lay/level hearth bricks but still wouldn't have felt comfortable laying them directly on Foamglas. The Foamglas is also not good with shock or impact. The tapping of the firebricks when leveling might have cracked the blocks too.
                  So the Foamglas has 2.5" of vermicrete on top of them and approximately 5" of vermicrete all around them. I basically encapsulated them in vermicrete - they shouldn't go anywhere now.
                  Regards,
                  Bob
                  • pizza_bob
                    • Apr 2008
                    • 181
                    #69
                    The Labor Day weekend allowed me some time to work on the oven.
                    I cut compond angles on the second course and mortared them in place. The time consuming part has been the transition from the course to the arch. Crazy looking brick(s) that tie the courses in with the arch. I don't see other ovens that needed to be tied-in so early?? I'm sure it's something I over-thought or screwed-up. I also had time to cut the compound angles on the third course and then dry stacked it to see where seams align (see aerial view below). I'll cut smaller bricks to avoid continuous seams. The bricks that tie the third course into the arch look even trickier than the previous. I'll attempt those cuts tomorrow.
                    ~Bob
                    • Dino_Pizza
                      • Feb 2008
                      • 1036
                      #70
                      Bob, your oven is looking great. The joints and brickwork is top notch. What is your final dome height? It looks like your oven will be a 42" low dome and that's great. Or maybe even though you are arching in (having to "tie" in to the arch in row 2 rather than 3 or 4) means your dome will be slightly lower than some. As long as you are on-course with your final dome height, your fine.
                      My Oven Thread
                      • pizza_bob
                        • Apr 2008
                        • 181
                        #71
                        Dino,
                        Thank you for the compliments. It's taking me way too long to get this far! I have to pick-up the pace - I want to finish before the snow hits!
                        The oven is a 42" diameter but I wanted a slightly lower dome. I am trying to get a 19" dome height. My template shows that I am on course to get that. I have a wooden template that I check each row with and then my indispensible tool is adjustable. I simply twist the brick holding bracket at the end of the indispensible tool a couple of turns until the brick position matches my form. The compound angle measurements that I cut on the bricks come directly from my SolidWorks design. The time consuming part for me are the bricks that tie into the arch. I just bought some green foam like you had in your pictures for trying to simplify the cuts for the bricks that tie into the arch. I'll let you know how I make out...
                        • pd360
                          • Jul 2009
                          • 2
                          #72
                          Bob, would you mind sharing your SolidWorks model? I use SW at work (I am a draftsman at a store fixture manufacturer) and I have just started my oven. Thanks!
                          -patrick
                          • pizza_bob
                            • Apr 2008
                            • 181
                            #73
                            The third course has been mortared in place. I figured-out an easy way to cut the bricks that tie into the inner arch. I basically took a piece of cardboard and cut it to the shape needed to fit against and around the arch. This shape was traced onto one side of the brick and then cut straight on the tile saw. Then I "safely" angle the brick with my "hand fixture" and cut the corect taper on the initial cut to match the angle of the inner arch (I apologize if this is difficult to follow but it worked ) See picture below.
                            I also cut the compound angles for all the fourth course bricks including the funky bricks that tie into the inner arch. I started mortaring the fourth course but only got half-way through. I noticed the bricks are a little shallow to achieve a 19" dome. I have to start compensating on the next row or else my dome height will be above 21" . I haven't been using the indispensible tool to hold the bricks in place - it never seems to hold it at the correct angle . I have been using the indispensible tool to maintain the circle but the angle has been eye-balled against my form.
                            I'll need to get more bricks and one more bag of HeatStop to finish the dome and last two arches. I have an extra bag of fireclay if anyone in the CT area is interested.
                            The funky bricks that tie-in to the inner arch are not perfectly symmetrical from one side to the other but no one will ever notice whenthe dome is closed. It looks as if I am avoiding the tear drop shape but it may be too soon to tell...
                            • mluttropp
                              • Oct 2008
                              • 79
                              #74
                              Wow you did an amazing job with the arch to chain connection. Mine looks terrible in comparison.
                              I enjoy cooking with wine, sometimes I even put it in the food I'm cooking. --- Julia Child
                              http://picasaweb.google.com/mattluttropp
                              • Dino_Pizza
                                • Feb 2008
                                • 1036
                                #75
                                Look great Bob. Excellent "funky" brick tied to the inner arch. I can appreciate the work that went into that cut. I can see that thin line of mortar on the inside bricks pushing your final height higher unless you compensate. I had the same problem but I couldn't get myself to butter the bricks from the back and leave the front (facing in) 1/4" without mortar so the bricks touch without a horizontal mortar line. I think that's were the "dome creep" happens.
                                Hey, maybe whoever picks up your extra bag of fireclay can swing by SoCal to pick up mine too !
                                My Oven Thread
