John's 42inch Aussie WFO
  • John K
    • Sep 2009
    • 216
    #76
    Re: John's 42inch Aussie WFO
    Had a busy day today.
    Completed the first row on the dome and will start on the second row tomorrow.
    Just wondering if there is a website that I can plug my arch dimensions so I can calculate how to splay and cut my arch bricks?
    I tried to get my hands on the angleizer but have been unsuccessfully.
    John
    __________________
    My Oven Thread:
    http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
    The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
    • jmhepworth
      • Feb 2008
      • 293
      #77
      I cut a big piece of cardboard to cover the floor and keep it clean. I really made a mess with mortar dropping, particularly as I went higher. I would not have enjoyed cleaning all of that mortar off the floor.
      Joe
      Joe
      • John K
        • Sep 2009
        • 216
        #78
        Absolutely agree Joe. I cut my plywood floor template into 4 sections today and have placed that on the floor. Beats cleaning mortar off the floor
        John
        __________________
        My Oven Thread:
        • John K
          • Sep 2009
          • 216
          #79
          Began on the second ring today and decided that I would splay these rings to provide me with minimum mortar thickness at the back. What a big mistake, it took forever to cut those damn bricks but must admit it is fairly tight.
          I set up my high tech jig to also cut the required inside angle as to avoid the internal V.
          John
          __________________
          My Oven Thread:
          • John K
            • Sep 2009
            • 216
            #80
            Some pics of the 2nd ring.
            I am utilising the rod to provide me with the required angle
            Is there a way to avoid the internal lip between the top and bottom bricks? Do people grind these level?
            cheers
            John
            John
            __________________
            My Oven Thread:
            • SCChris
              • Jun 2009
              • 1213
              #81
              John, for brick cutting I created a tool to set the radius from the axis of the hemisphere and hold the brick at the correct course angle. Although my 10" saw didn't, couldn't, get deeper than a 3.5" cut, it set the angles that allowed me to complete the side cuts. The tapering of the bricks, taking 1/2" off the top front inside of the bricks, was done with a simple jig.
              "http://www.fornobravo.com/forum/f28/new-brick-cutting-tool-old-tool-7649.html"
              Here is the thread from the tools forum.
              Chris
              • jmhepworth
                • Feb 2008
                • 293
                #82
                Ignore the lip. Once you get fire in the oven, you stop looking at the minor imperfections.
                Joe
                Joe
                • SCChris
                  • Jun 2009
                  • 1213
                  #83
                  Joe's right! Without that brick milling machine getting a mirror finish on the interior would be a real bear..
                  Chris
                  • John K
                    • Sep 2009
                    • 216
                    #84
                    Hi Chris your tool looks great but well beyond what I could probably create. I'm glad you were able to create something to help with your cuts and am sure you had fun designing it too.
                    I will stick to the old fashioned shims as they seem to work okay. Keep on creating those tools!!
                    John
                    John
                    __________________
                    My Oven Thread:
                    • John K
                      • Sep 2009
                      • 216
                      #85
                      Joe
                      Thanks Joe I'll try my best to pretend that they are not there
                      John
                      John
                      __________________
                      My Oven Thread:
                      • John K
                        • Sep 2009
                        • 216
                        #86
                        Completed the second ring and have begun on the 3rd.
                        I decided not to splay the 3rd ring as it was very time consuming and my cutting blade is on it's last legs. Will need to source a new 14inch blade in the coming days.
                        John
                        __________________
                        My Oven Thread:
                        • John K
                          • Sep 2009
                          • 216
                          #87
                          My brother in-law was kind enough to calculate my arch brick dimensions based on a template I had provided him
                          It looks like I will need 11 bricks
                          The attached scan has not allowed for any mortar joints but I will look at the final dimensions and factor in a 6-8 millimeter joint.
                          John
                          __________________
                          My Oven Thread:
                          • ThisOldGarageNJ
                            • 1436
                            #88
                            Hi John,
                            Your brick & Mortar work is looking really good, Very nice joints...
                            Keep up the good work,
                            Mark
                            • SCChris
                              • Jun 2009
                              • 1213
                              #89
                              John, I agree with Mark, your brickwork looks great!! Take your time and don't worry about the little things.
                              Chris
                              • John K
                                • Sep 2009
                                • 216
                                #90
                                Thanks Guys. As I have never worked with bricks before I am really enjoying myself!
                                Mark, I saw your pics of your WFO and it is looks great. I was unable to find a link to your thread though? Do you have one?
                                regards
                                John
                                John
                                __________________
                                My Oven Thread:
