John's 42inch Aussie WFO
  • #61
    Re: John's 42inch Aussie WFO
    I have a question around the chimney landing. I will be building the front bricks out of a purple coloured brick (as per the oven base) but there will be no way to tie in the landing Chimney bricks with the arch bricks. Will this be an issue??? I will source some brick ties to mortar in for stability but am hoping for some direction.
    I'm afraid I don't understand the question - perhaps you could give us a sketch to clarify what you're asking?
    • #62
      Hi Dmun,
      I was not very clear with my question. As per the below diagram as I will not be using fire brick for the landing bricks so will need to butt my landing bricks to my oven brick arch (hope this makes sense).
      I was concerned that this might be an issue down the track
      John
      __________________
      My Oven Thread:
      http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
      The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
      • #63
        Ok, Now I understand. There is no problem having dissimilar bricks in that place, in fact it's a notorious cracking area because of the temperature differential between the hot dome and the cooler entry. If you are concerned, you could engineer a slip plane between the two dissimilar materials, they make a special refractory paper for just that purpose, or you could just ignore any cracks that develop, like the rest of us.
        • #64
          You could also leave a 10mm gap and fill it with perl or vermicrete
          My 2nd Build:
          Is here
          • #65
            I think with mortar and ties you'll be fine
            • #66
              Much appreciated guys.
              Now I don't feel as bad. In that case I will just use some brick ties and unfortunately expect some cracking in the mortar
              Cheers
              John
              __________________
              My Oven Thread:
              • #67
                it MIGHT crack,,,, doesnt mean it will.... and if it does it will be hard to see from my house.. relax, and think of the cracks as charachter......
                • #68
                  If it does crack,
                  it'll get covered with soot anyway
                  out of sight... out of mind!
                  My 2nd Build:
                  Is here
                  • #69
                    Originally posted by ThisOldGarageNJ View Post
                    it MIGHT crack,,,, and if it does it will be hard to see from my house..
                    lol you sure Mark, Google Earth is a pretty powerfully tool you know
                    Mitchamus I agree the soot will probable cover most of the imperfections any way
                    cheers
                    John
                    __________________
                    My Oven Thread:
                    • #70
                      Began work on the chimney landing bricks today. Things went well and layed 3 courses. I utilsed brick ties to to reduce any cracking as those bricks do not overlap.
                      I also cut out 1 of 2 templates for my brick arch supports so I will have a busy couple of days in front of me
                      Cheers
                      John
                      __________________
                      My Oven Thread:
                      • #71
                        It's looking really good. I see one potential concern that I'm a little hesitant to point out because you probably already know this. It looks like the wood in the 4th picture is a pattern for your arch. When you make your arch form, make sure it is short enough to shim underneath the form. After building the arch you might not get the form out without damaging the arch if you don't have shims you can take out first.
                        Joe
                        • #72
                          +1
                          Nice block work!
                          My 2nd Build:
                          Is here
                          • #73
                            Great call JM....... I wouldnt have noticed until you pointed it out...
                            • #74
                              Hi Jim
                              You have a great eye their. The template was used to give me the overall height of the 3 arch bricks. I hadn't thought that far ahead but will definitely take your advice and shim it up once cut to size.
                              John
                              __________________
                              My Oven Thread:
                              • #75
                                Originally posted by Mitchamus View Post
                                +1
                                Nice block work!
                                Thanks Mitchamus
                                That was the easy bit!!
                                I guarantee the arch work won't be as clean!!
                                cheers
                                John
                                __________________
                                My Oven Thread:
