unique oven enclosure - Forno Bravo Forum: The Wood-Fired Oven Community
  • unique oven enclosure
    we started this oven with the idea of using a steel dome as the inner
    oven form, but decided to go with traditional brick construction.
    you can see the beginning here http://www.fornobravo.com/forum/f43/...oven-7739.html
    Re: unique oven enclosure
    we got some more work done this weekend.
    cut the soldier course with the water cooled chop saw.
    set the floor bricks, and set our soldier course for a trial run.
      looking great man....
        Just wondering (still learning the physics of this) won't it take a long time to heat up all that thermal mass? will it act like a heat sink?
          Joey,
          From his other thread - he filled that thing with perlcrete (perlite + portland). His oven will be very well insulated underneath.
          Ken H. - Kentucky
          42" Pompeii
            Originally posted by Ken524 View Post
            Joey,
            that is what I was wondering about, won't the perlcrete act like a heat sink and he will have to heat p up the entire thing before it will begin to release the heat back? = alot of wood
            maybe I am overthinking this?
              if that is true then we will have to cut down more almond trees to feed the fire
              there is 40 cubic feet of perlite in the bottom of the ball.
                it will act as insulation and keep the heat reflecting back into the bricks.....same as the insulation in your house would work, the perlcrete should be faily light and airy when mixed properly,, I think if lined with just cement it would act like a heat wick and suck the heat away,,, the perlcrete helps keep the heat more where the fire and firebrick floor is...
                My explanations arent always that good.... here is what wikipedia says
                A heat sink (or heatsink) is an environment or object that absorbs and dissipates heat from another object using thermal contact (either direct or radiant). Heat sinks are used in a wide range of applications wherever efficient heat dissipation is required
                The term thermal insulation can refer to materials used to reduce the rate of heat transfer, Thermal insulation is the method of preventing heat from escaping a container or from entering the container. In other words, thermal insulation can keep an enclosed area such as a building warm,
                Mark
                  I are confused. What does that have to do with the enclosure? I don't get it.
                  Maybe I should take up coffee drinking in the morning...
                  [/CENTER]
                    I are confused
                    welcome to the club,,,, we are talking about the base... not the dome .....Wake up archie... P.S. I had the coffee it didnt help
                      That is going to be cool set up!
                      Now, you'll need a bunch of these to go with it.
                      George
                      My 34" WFO build
                        It should be illegal for modernists to design outdoor furniture.
                        Modernism is dead, people. Let it go already!
                        Don't get me started on Zen style... <insert ranting smilie here>
                        [/CENTER]
                          here are a couple of the latest progress pics
                            MM,
                            Looking great, glad to see the magic 8 ball pizza oven is rolling on,, You are not fara way now...
                            Nice Work
                            Mark
                              that is one cool brickholding tool...
