Re: Dave's Northern Virginia Build
Hey Dave, your flu transition and chimney look good. Having made that transition tall with the angled up brick sides was a good idea.
As for curing, how about putting a cover on that cute thing and use a slow, electric heater? I think if you covered it to keep it dry, it would work. But I am TOTALLY UNFAMILIAR with cold weather building and its affect on hot ovens. Maybe really low heat without the blanket for a few days (to drive out moisture) , then the same heat with the blanket for a few days (the blanket will retain heat and it will get hotter naturally, then move up to pizza temps?
I got the curse of the crack on my oven so I don't have a good track record
Nice job, keep it up, Dino
.Nice job, keep it up, Dino
