Re: Tom's 42' Pompeii, Penn Valley, Ca.
Tom - That may be a bit aggressive, call Domino's.
I think building into the arch is the biggest challenge. Keep your eye on the level. Almost every build has had a drop at this point. It's not a game stopper, but you will be fighting to get back to round and level in the succeeding rings. A simple tarp set up can keep you dry - at least you are not fighting the freezing ass temps that most people on this side of the orb are experiencing.
Good luck with the build!
Les...
I think building into the arch is the biggest challenge. Keep your eye on the level. Almost every build has had a drop at this point. It's not a game stopper, but you will be fighting to get back to round and level in the succeeding rings. A simple tarp set up can keep you dry - at least you are not fighting the freezing ass temps that most people on this side of the orb are experiencing.Good luck with the build!
Les...
