If you had the chance to rebuild your oven, what would you change?
  • Tscarborough
    • Oct 2009
    • 3341
    #106
    Re: If you had the chance to rebuild your oven, what would you change?
    Length-wise cuts are not a problem, small pieces are, and this is for under walls, so round really doesn't matter.
    • Amac
      • Nov 2011
      • 358
      #107
      In that case OK - but some of those I had already cut lengthwise with the anglegrinder I wasn't happy with and re-cut them crosswise. Ended up I couldn't reuse any of the lengthwise cuts but I was happier with the new cuts.
      Amac
      Link to my WFO build
      • Tscarborough
        • Oct 2009
        • 3341
        #108
        Lengthwise cuts are no fun with a grinder, I agree.
        • banhxeo76
          • 194
          #109
          If I had a chance to rebuild my WFO................ I would build it without being married. No wife to complain about me spending to much too time with my true love.
          Who Dat?
          Tu Dat
          If you feel lost with building your WFO, just pray to St. Stephen who is the patron saint of bricklayers.
          • Amac
            • Nov 2011
            • 358
            #110
            Didn't realise she'd driven you to those extremes tu - but that won't work in any case - you need a gas oven
            Amac
            • stonecutter
              • Jun 2007
              • 2003
              #111
              Ha....the first one I built at our home, the good woman called herself a WFO widow. She doesn't mind this time around, because of how much she enjoyed the first one. Or she just doesn't miss my company...either way, I'm happy to be building another.
              Old World Stone & Garden
              John Ruskin
              • midtown
                • Feb 2013
                • 2
                #112
                I would make it bigger, (mine is about 1m in diameter), and my doorway is a little narrow, and a bit deep, otherwise, this is probably the best home built thing ever!
                • vtsteve
                  • 110
                  #113
                  I've been baking in my 42" Pompeii (4.5" floor, no cladding, 17" dome height) every week or two for a year now. I work nights, and I usually do pizza for lunch & leftovers (2 or 3 18-20" NY style, or a dozen Neapolitan when the weather is warm). The next day I've got 400+ degrees, so I burn a moderate fire for a couple of hours and bake 20-30 loaves of bread. If I were to build again, I'd go bigger (46-48") and lower (14" or so). And maybe mobile (or at least towable)...
                  • Spunkoid
                    • Jul 2009
                    • 109
                    #114
                    I put in a soldier course on the bottom row, not necessary, with a 1 meter diameter, the dome would have had sufficient height.
                    • lwood
                      • Jul 2009
                      • 632
                      #115
                      Agreed Spunkoid, especially if you want a low dome oven. The issue gets worst as you increase the dia. I have a 60" oven and I would definitely remove the soldier course and start the dome right at the floor.
                      • Spunkoid
                        • Jul 2009
                        • 109
                        #116
                        On a similar thread, one thing that I did that I really like and get rave reviews for is I found and old wall mount bottle opener and I screwed it onto the forno. Everyone comments on it and it gets regular use during any of our get togethers.....
                        • texman
                          • Nov 2009
                          • 724
                          #117
                          Just want to post here to bring this thread back to the top for awhile. Really good points in here to consider for the class of 2013 and beyond and it was hard to find this thread.
                          For me, I would use homebrew and save $$ and probably build a smaller oven. 36" takes awhile to get to pizza temp. The size is great, but i think a smaller would heat faster and get used more. Not sure, just wish i had time to use it more.
                          Texman
                          Texman Kitchen
                            A smaller oven doesn't mean faster heat up because a smaller oven has a smaller fire. It is the thickness of the walls and their conductivity that govern how fast it will heat. My oven is only 21" and has 2" walls, it still takes an hour to clear and an hour and a half to get to proper pizza temp. If I'm cooking for a big crowd I'll give it two hours of fire.
                            • texman
                              • Nov 2009
                              • 724
                              #119
                              david s
                              That is about exactly what my oven prep times are. Takes 1.5 to two hours to clear. Not sure what a complete saturation is just yet and not sure how to tell. So it just takes a while to get them to temp for pizza whether small or larger. More mass=more time but more retention. For some reason i had it in my head the smaller ovens were quicker to heat. Thanks for the clarity.
                              Texman
                              Texman Kitchen
                              • Filthymutt
                                • May 2010
                                • 187
                                #120
                                Time. I would change time. As in give myself more of it. I definitely did this oven with one eye always on the clock. I rushed it and it came out sloppy. Not what I intended at all.
                                Ok this was my first and in no way a permanent oven for me but a favor to my landlord. When its time to leave in 3.5 years she gets a brick oven with some years still left on it.
                                This was a practice oven to show me what I would do wrong. And the biggest mistake was time and lack of patience.
                                Next oven I will shape and form every chain of bricks, Build a jigsaw from scratch. Make it pretty. And do it somewhere outside of China where I can buy bricks of uniform size and quality, not the hodgepodge I got to work with.
                                But that is it, what I would change first, TIME.
                                BC
                                Bob
                                Always ready for pizza
                                http://www.fornobravo.com/forum/memb...ing-build.html
