Blast Door
  • brickie in oz
    • 3445
    Blast Door
    I built a blast door to get the initial fire going, its made of thin sheet metal and a few cheap shelf brackets.
    The fire roars into life with the blast door. (fire is 2 minutes old)
    YouTube - ‪OrgasmoTheGreat's Channel‬‏
    My oven is a barrel type with a flue inside the oven (blocked off with a flue damper) if you have a Pompeii type the same door could be used but on the outside.
    • 2848
    Re: Blast Door
    Dear Brickie
    whats the principal behind this? supplying the air down low while reflecting the heat? still letting the smoke to escape...
    Regards Cobblerdave
      Re: Blast Door
      There's a lot of discussion on this topic, under the name of "draft door"
      • Wiley
        • Mar 2008
        • 804
        Re: Blast Door
        Brickie,
        If you get the opening sized just right your WFO might pant like mine does.
        YouTube - ‪Panting Wood Fired Oven‬‏
        By increasing the size of the opening just a little bit this panting doesn't occur and with the opening at the present size it stops once the chimney gets hot. The panting only lasts for a few minutes.
        Bests,
        Wiley
        • brickie in oz
          • 3445
          Re: Blast Door
          I doubt mine will pant as my flue is in the top of the oven itself.
          It would be cool if it did though.
          • GianniFocaccia
            • Jun 2009
            • 1645
            Re: Blast Door
            Wiley,
            Is this a Pompeii with the blast door enclosed at the top/open at the bottom only?
            • brickie in oz
              • 3445
              Re: Blast Door
              Correct, it forces the air into the fire where its needed and makes it draw better.
