I built a blast door to get the initial fire going, its made of thin sheet metal and a few cheap shelf brackets.
The fire roars into life with the blast door. (fire is 2 minutes old)
YouTube - ‪OrgasmoTheGreat's Channel‬‏
My oven is a barrel type with a flue inside the oven (blocked off with a flue damper) if you have a Pompeii type the same door could be used but on the outside.
