Re: How to make a wooden post relatively removable from concrete
"Dont you guys have these over there?"
Yes Al, we do. If fact building codes require these or similar fasteners for fixing posts to concrete. Sinking a wooden post (even a pressure treated post) into concrete is not a proper solution any more.
If you want to deal with bending moment using a single post, the preferred solution is a steel angle or channel with the post bolted to it.
