Re: How to make a wooden post relatively removable from concrete
"Dont you guys have these over there?"
Yes Al, we do. If fact building codes require these or similar fasteners for fixing posts to concrete. Sinking a wooden post (even a pressure treated post) into concrete is not a proper solution any more.
If you want to deal with bending moment using a single post, the preferred solution is a steel angle or channel with the post bolted to it.
aint" it with anything. The only other preservative that I an familiar with that is applied by brush is Creosote, that black smelly and sometime sticky material.
