Harringbone Pattern - Forno Bravo Forum: The Wood-Fired Oven Community
See more
See less
Harringbone Pattern
  • Harringbone Pattern
    So the oven plans that I have call for harringbone pattern for the hearth. Is there any advantage to doing this to make the extra work worthwhile?
    Re: Harringbone Pattern
    Originally posted by Karangi Dude
    Setting the hearth bricks in a herringbone pattern at 45 degrees will alleviate problems like the peel, pots or pans from catching on the joins.
    Thanks sounds like its a good idea to do then. I will incorporate it into my build this summer
      The big T
      I really don't understand where your thoughts are mate!
      How much extra work is there from laying the bricks in a Herringbone pattern, Stacked bond or as a brick wall pattern, known as Running Bond.
      See the pattern alternatives here:
      Patio Brick Patterns
      Neillís Pompeiii #1
      Neillís kitchen underway
