Checking the internal temp of meat?
Re: Checking the internal temp of meat?
I like raw oysters
[/QUOTE]
It's strange that raw oysters have entered this discussion. They are also reputed to increase the elevation of your tool, with or without wires and batteries.Last edited by david s; 01-21-2014, 09:47 PM.Kindled with zeal and fired with passion.Comment
Last edited by Gulf; 01-21-2014, 10:20 PM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
Let me re-phrase my answer.
What Mitchamus said: you don't have to re-calibrate a thermometer for altitude. If it is right at sea level it will be right at altitude.Comment
What I said
I'm very sorry that I wasn't clear. I did not say anything about "recalibrating for altitude". But, if you know the boiling point of water for your "elevation" (altitude) you can "test" your thermometer. I live close enough to sea level to use 212 F. Denver Bronco tailgaiters would use 202 degrees. I don't have any of the digital probes. But the manual probe that I use the most is about 2 degrees low. When probing for internal temperature, I take that into consideration.No matter what the device, digital or manual, you may have to test the tool for your elevation and adjust your "readings" accordingly. Here is one site that has a chart
. (Sorry it is in fahernheit) If it ain't close, you may want to return it or throw it a way.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
That's the trouble with the English language, it's never clear. I really did read your post as suggesting that you need to adjust the thermometer for altitude.What I said
Apologies. I'll shut up now.Comment
ll, I like raw oysters
