Home brew mortar problems
  • antwlo
    • Aug 2016
    • 14
    I have been using Heat Stop so far, and everything was ok. I decided to switch to a home brew mix with ratio of (3:1:1:1) 3 parts sand: 1 part portland cement: 1 part lime: 1 part fireclay.
    I mixed everything and did my first application today with the new home brew. Something is wrong!! the mix is not holding together. It's crumbling and not sticking on the firebricks. I made the mix a bit more "liquidy" by adding more water. I just tested an area that dried off, and the bricks came apart and the mix basically crumbled in my hand.
    What am I doing wrong?
    Please help
  • dakzaag
    • Jun 2014
    • 235
    Try 6;1;1;1 use really fine sand. I like to add more lime and less Portland Why did you switch? maybe the heatstop would be better for you in the long run..
    • thevance53@gmail.com
      • Jul 2016
      • 72
      should be fine. That is what I am using and it is working great. Make sure you are using the right lime and mortar fireclay. I mix dry ingredients and then add water and mix until slightly creamy. Try a small trial batch? I use a small tuperware bowl and do it by roughly measured parts. Not an exact science for me and seems to work fine. Are you wetting your bricks? I soak the bricks and then mist the receiving bricks so they don't suck the moisture out of the homebrew. Let us know if you figure out the issue.
      • antwlo
        • Aug 2016
        • 14
        My problem was not wetting the bricks first. Once I soaked them, the home brew worked. Thanks for the advice
