I have been using Heat Stop so far, and everything was ok. I decided to switch to a home brew mix with ratio of (3:1:1:1) 3 parts sand: 1 part portland cement: 1 part lime: 1 part fireclay.
I mixed everything and did my first application today with the new home brew. Something is wrong!! the mix is not holding together. It's crumbling and not sticking on the firebricks. I made the mix a bit more "liquidy" by adding more water. I just tested an area that dried off, and the bricks came apart and the mix basically crumbled in my hand.
What am I doing wrong?
Please help
Please help
