G'day All,
I've just started to build my oven, not much there yet but it's in construction under 42 inch build in Adelaide.
Couple of questions;
What is the latest in relation to thermocouples/temp sensors built into ovens now that the hand held infrared temp measuring devices are readily available for minimal $ ??
In relation to an IT tool;
1 How important is the clamp? Will the brick rest there in place anyway?
2 Is it necessary to adjust the length shorter every use to get it out without dislodging the brick you've just fitted? I'll will make mine adjustable bit this will determine how easily one would want use of the feature.
3 I've learned that the rod connecting at the bottom is best aligned exactly with the top of the oven floor brick, and in dead centre. I cant seem to get my head around where it should align with the top brick. Is in the centre?
Kind Regards and many thanks
Greg
Greg
