full or half bricks
  • steveog
    • May 2020
    • 3
    full or half bricks
    Im building a pizza oven and following the process that is spelled out on these forums - cinder block base, 3.5 inch of rebar supported concrete with 2" of FB insulation board, toped with fire brick. Unfortunately, I was only to find half bricks locally and wondering if they will carry enough thermal mass?
  • P3 Stoaker
    • Oct 2019
    • 135
    G'day. When you say half brick, I assume you mean half thickness? How thick are you talking?
    Adelaide, Australia.
    • steveog
      • May 2020
      • 3
      Sorry for not being more specific. Yes, half thickness at 1 1/4 inches. I'm hoping they have enough thermal mass. If not, what do you think might be the minimal brick thickness or a possible alternative?
        • 5259
        1.25" thick are know as splits, In order to have enough thermal mass in the floor you will need to do a double layer of splits.
        • steveog
          • May 2020
          • 3
          awesome, thanks!
