Great way to start your fires.
  • geisen
    • Jan 2009
    • 217
    For all those who don't want to waste time with paper, kindling or fatwood; hit it with the natural gas.
    My BBQ is hooked into my house natural gas line and is only 6 feet away from my 42" WFO. Add a "T", a couple of shut off valves, quick-connect, 10ft of gas hose, and three feet of gas pipe and you got yourself a fire stick. I drilled small holes an inch apart in the last 12" of the gas pipe.
    Lay the pipe in the WFO with the gas OFF. build your wood pile in the criss-cross pattern above the pipe. Light a fireplace match and set it next to the pipe. Turn on the gas slowly and you got yourself a fire. AT full power I only need to leave the pipe in for three minutes. Turn it off and pull it out..Carefully.......it is hot.
    Greg Geisen
    Chula Vista, CA
    Click to see my Thread:
    http://www.fornobravo.com/forum/f8/g...iego-6169.html
    Click to see Google web album:
    http://picasaweb.google.com/gpgeisen...eat=directlink
  • Mitchamus
    • Aug 2008
    • 389
    Re: Great way to start your fires.
    the flame looks really yellow... do you have a mixing hole near the gas inlet? (like on a gas grill burner)
    My 2nd Build:
    Is here
    • geisen
      • Jan 2009
      • 217
      Hadn't thought of that. What do you suggest?
      Greg Geisen
      Chula Vista, CA
      • Mitchamus
        • Aug 2008
        • 389
        Hmmm.... not sure
        I'm not sure how big the hole would need to be to provide the right mixing...
        I would take a look at the size & position of the hole on a regular grill burner... and shoot for something the same size so start with...
        but.. if it's working fine for you as is... why mess with it? I just wondered is all, because I was thinking of making something similar at one stage...
        My 2nd Build:
        Is here
        • Les
          • Sep 2005
          • 2945
          I went the easy route, harbor freight sells a weed burner and I had a propane tank for camping.
          Greg, your approach is cool. I HAD to buy this to get the weeds out of my rock - then one day I said, what the hell. From then on, the WFO is fired
          Sorry about the quality - it was obviously dark when I recorded this.
          YouTube - A tool for lighting fires.
          Les...
          • Mitchamus
            • Aug 2008
            • 389
            jeebus!
            forget the fire... make yourself a hot air balloon!
            My 2nd Build:
            Is here
            • Les
              • Sep 2005
              • 2945
              Originally posted by Mitchamus
              jeebus!
              Thats funny! There have been days where I thought my oven may ascend into the clouds
              Les...
              • brokencookie
                • Oct 2007
                • 376
                I have one just like Les I use for my portable pizza oven. When I get in a hurry I roast the top of the bricks with it. The IR themometer shows I can get up to 1000 degrees this way. It also works as a quick recharge between pizzas since I do not have a live fire going.
                On the down side, my wife thinks it sounds like a jet engine and the dogs howl.
                • RTflorida
                  • Jan 2007
                  • 1446
                  Les, I love your final word on that video.......COOL!
                  Thats somes up every new gadget and tool I get....I tend to be a little harder and longer on the "K" - KKOOOL!!!
                  I'm not ashamed to admit - at times I act like a 5 yr old on Christmas morning.
                  Another favorite I tend to yell out - "YOU'VE GOT TO COME SEE THIS!!!
                  I will say this.....I've got to get one of those weed burners, they are like a plumbers torch on steroids
                  RT
                  • geisen
                    • Jan 2009
                    • 217
                    The weed burner is definately "cool" and having been around jet engines when the test them off the back of an aircraft carrier, it does have a similar sound, except i bet your ears aren't bleeding.
                    I thought about going with the weed burner but didn't want to buy a propane tank and store it when I had NG right on site. For anyone who has tried hooking up a propane grill to a NG source .......it doesn't work too well without a conversion kit for flow and hole size.
                    Thus the NG fire stick.
                    Greg Geisen
                    Chula Vista, CA
