For all those who don't want to waste time with paper, kindling or fatwood; hit it with the natural gas.
My BBQ is hooked into my house natural gas line and is only 6 feet away from my 42" WFO. Add a "T", a couple of shut off valves, quick-connect, 10ft of gas hose, and three feet of gas pipe and you got yourself a fire stick. I drilled small holes an inch apart in the last 12" of the gas pipe.
Lay the pipe in the WFO with the gas OFF. build your wood pile in the criss-cross pattern above the pipe. Light a fireplace match and set it next to the pipe. Turn on the gas slowly and you got yourself a fire. AT full power I only need to leave the pipe in for three minutes. Turn it off and pull it out..Carefully.......it is hot.
