cobblerdaves build
  • Bacterium
    • Apr 2007
    • 560
    #46
    Re: cobblerdaves build
    Looking good Dave
    Damon
    Build #1
    Build #2 (Current)
      • 5260
      #47
      Dave,
      Congrats, no one will ever see the small wedge. They will just marvel at your oven.
      • Camori
        • Jul 2012
        • 59
        #48
        Dave, that looks fantastic, Wish I had of thought of that.
        Camo
          • 2848
          #49
          Camo
          Gudday
          Thanks for the kind words ..... But that's the point I didn't think of it all by myself! Yes there is some brick covered domes which I admired. V-wiz came up with the brick veneer idea and I thought ....YES now I have enough room.
          You have to thank James and the forum to allowing us to throw ideas around
          • reccymech
            • May 2013
            • 20
            #50
            Excellent thread Dave. Got a heap out of it. Looking forward to starting my WFO.
            Have already downloaded the FB plans, had a read last night. Most likely going to go with 'the flow' and build mine from scratch.
            • reccymech
              • May 2013
              • 20
              #51
              Read your thread CD. A wealth of info for the novice. I only hope my WFO is half as good.
                • 2848
                #52
                Gudday
                Rained off and on all week and the today yep you guessed it rained again. Which is great. Let me make some more progress.
                You are probably thinking at this stage I have gone bonkers , but it has been heaven sent. Course can't finish the tiling, but the week of rain has gone well to soften the lime scale over the oven!
                Broke out the scrubbing brush and a bottle of vinegar and gave the bricks a good scrub. Now vinegar isn't the best choice for removing lime scale but its pretty soft on the skin ,cheap and after a week of weathering works a treat.
                Add a pressure spray down and.....
                Now it just has to stop raining so this puppy ill dry out and I can put on some brickseal and were done ....almost
                • brickie in oz
                  • 3445
                  #53
                  Dave save your vinegar for the fish and chips, once the water dries off the oven the scale will still be there.
                    • 2848
                    #54
                    Gudday
                    Beg to differ .... But it does work. Have you never used it brickie. Anyway it's perfect for my needs. Those old bricks I want to remove my lime scale only and leave the pantina of old mortar etc cause there old bricks and I want them to look that way.
                    If you really want to wipe the surface clean so to speak and still keep from buying heaps of stuff you can use ....
                    Use diluted hydrchloric acid pool suppliers ( small amount for spa )or best somone with a pool cause you don't need much.
                    Or deck clean from the hardware contains 10 per cent a asolic acid.
                    • brickie in oz
                      • 3445
                      #55
                      I have used it, thats why I know it dont work.
                      • Bacterium
                        • Apr 2007
                        • 560
                        #56
                        Dave the overall look you've got going there is good.
                        Not sure if I'm a vinegar kinda person or not
                        It's a good view sitting on the fence
                        Damon
                        Build #1
                        Build #2 (Current)
                        • Cookie Monster
                          • Nov 2011
                          • 56
                          #57
                          Nice looking oven Dave. you have done a great job!!!
                          Do you get any heat transfer through to the outer shell when you fire the old girl up?
                          Cheers,
                          Matt
                            • 2848
                            #58
                            Gudday Matt
                            No that will not be a problem. I have 50 mm of ceramic and 100 mm of rockwool , the outer surface will remain cool
                            I do not have a heat break so a little heat gets to the entrance but you will not feel it till next day . It's not hot but above the air temp so you could lay your hand on it all day. Chimney much the same, may be hot on the inside but by the time that heat migrates to the outer surfaces its quite cool.
                            Have a look at Karangi Dudes build he has a set of readings of how the heat migrates through the brick.
                            Regards Dave
                            • stonecutter
                              • Jun 2007
                              • 2003
                              #59
                              Gudday
                              It is good for what you did CD. Acid is often made too strong, and it attacks the mortar in the joints as much as cleans up staining.
                              Old World Stone & Garden
                              John Ruskin
                              • Xene
                                • Apr 2012
                                • 125
                                #60
                                Wow! I love the igloo bricked, I had considered that in my build but I knew I couldn't pull it off and I was so sick of cutting brick by the time I got that far that I went with the stucco. Love the door and the recycled brick and your doors below are awesome too, which reminds me, I still need to have my lower door made; I've been too busy with pizza making to even think of it. I like your aesthetic.
                                My oven album is here
                                sigpic
