new build in werribee
  • Re: new build in werribee
    Thanks Guys will check all that out. trouble with flue manufacturers is the limit too 900mm length pipe.
    Gudday Colin
    You haven't compromised on anything to date so the flue is no exception.
    What's the minimum buy amount? Is it sensible to buy that amount and sell them on the forum ,gumtree, eBay? It is winter its the season to sell flues Just a thought
    Regards Dave
    Thanks Dave I thought about that but minimum buy is 100. But I haven't been able to find a supplier directly only things like alibaba. Don't have that sort of money.
    Originally posted by stonecutter View Post
    You are paying $3.30 per brick? Wow...that's more than triple than around here.
    Yeap. Stonecutter that's the price down here. EVERYTHING COSTS THE EARTH in Australia.
    Originally posted by TropicalCoasting View Post
    I put in a few flues for fire places in Melbourne
    Cheapest I found was Wood Heaters Melbourne, Gas Log Fires Melbourne, Flues Melbourne | Just Flues
    it was a while ago though
    Tropical spoke too the owner he was to give me a quote but never received however he couldn't do longer than 900mm
    Cheers Colin
      Nice tapered arch Colin, yes it is pretty and you can say you did it all yourself.
        Thanks Russell. Are you referring inner arch?
        Cheers Colin
          Really all of your build but the inner arch or the inner part of the tapered arch is very nice.
            Russell I see, still get lost with terminology but I have many others to thank that went before me for developing the technique.
            Very appreciative of them all and thank you for the compliment Russell, feel though the hard part is left to do, the last 4 courses and that landing I'm playing with.
            Cheers Colin
              Colin,
              Have you seen/considered a flashing cone as a transition to you flue?
              The gas heating brochure here is a read
              PRODUCTS
              Also have a local steel fabricator who will roll a flue in 1200mm
              Cheers
              Damon
              Build #1
              Build #2 (Current)
                Hi Damon
                I will check it out thankyou. Damn I didn't get quote I was after.........
                Cheers Colin
                  Plan B it is then......
                  My Build.
                  Books.
                    hi brickie
                    wt....... was plan B................. I've been looking at this for 2 months.
                    Cheers Colin
                      at least guys
                      Cheers Colin
                        AWF Sheetmetal
                        try these guys
                        I used to get lots of metal bent by them Im pretty sure they do SS and down pipes so they should be able to make a flue
                        again years ago
                          Hi tropical
                          have contacted them too. I'm beginning to think what I am seeking is not possible. but as Dave pointed out I haven't compromised at this point so why should I start now.
                          Cheers Colin
                            Hey tropical
                            Well check out awf sheet metal. Someone else put me on to them. The quote I got still too high st 680. Then I would still need a cap.
                            When I rang awf they seemed to be more reasonable.
                            Cheers Colin
                              Ive bought zinc caps of them in the past,they would probably make you a ss one.
                                Well finally a break on the flue $500 delivered to the door if all goes well via fishpond.com.au direct from US previous cheapest price was $760, to get fabricated in Victoria $680 plus a flue cap from somewhere. Superpro flues are Selkirk. So Russell Yipppppeeeeeeee... So we can use Russell's and Dennis's sexy flue in Aus.
                                1x Chimney 77806 8 in. x 48 in. Superpro Factory-Built Chimney Length-304-alloy Inner And Outer Walls
                                Estimated delivery date: 25th Jul - 8th Aug from USA supplier
                                $279.00
                                1x Chimney 77847 8 in. Superpro Adaptor Plate- Galvanized With Stainless Collar
                                $79.95
                                1x Chimney 77855 8 in. Superpro Rain Cap- Deluxe- Stainless
                                $142.00
                                So lets now see what happens............. fingers crossed.... Fishpond also responded saying advertised prices are in $AUD
                                Cheers Colin
