Hi All,
New to the forum, decided to post. Just finished building a new house and decided to install an outdoor BBQ/ kitchen area. I'll post my progress as I go, but for now I'm researching and collecting materials.
This is the second oven I'm making, the first was based off russell jervous book and a few other ideas.. So it was made with 'pressed reds' for dome and base with vermiculite cement insulation and render dome. It turned out well and has been utilized well, only problem was the insulation has cracked
, but this doesn't affect the performance.
Anyway this time round I intend to rectify my errors and try to mitigate against the cracks. Watched all the vid's on YouTube, read the forums and have decided to spend a bit of extra $ and build with recommended materials, and hope for the best
So, this is what I'm planning, any suggestions or advise is welcome.
1100 internal dome, but this time have decided to use firebrick for base and dome. Two or three layers of Ceramic blanket and chicken wire then layer of vermiculite and cement, more chicken wire then two coats of render and wire finished off with waterproof sealant as the oven will be exposed to the elements.
I've posted another thread looking for suppliers and have now found what I'm looking for. So went to Morgan Thermal Ceramics at Beverly and found they have just about everything refractory. They got bricks for $4.40ea and also the 50mm floor tiles for about $15 each.their blankets they call superwool.
Not sure whether to use the bricks or the 50mm floor tile for the base?
They also sell the subfloor insulation, but they've got stuff called V1100 which is a vermiculite product (25mm thick) not the other FB? stuff others tend to recommend. Any suggestions?
The other thing is the mortar. I can get the 'poor mans mortar' or Thermal Ceramics also sell 20kg drum of 'Blackite mortar' for $60. I haven't heard of the stuff before but would be happy to use it if anyone knows anything about it and if it's suitable. This stuff comes wet, so no mixing just scoop it out and use it.
I want to keep the mortar to a minimum on this build.
For the waterproof layer, was thinking of using this stuff called 'emer-clad waterproof membrane, which I see another Pompeii builder used on YouTube
Any advice would be appreciated.
Thanks Rob..
, but this doesn't affect the performance.Anyway this time round I intend to rectify my errors and try to mitigate against the cracks. Watched all the vid's on YouTube, read the forums and have decided to spend a bit of extra $ and build with recommended materials, and hope for the best
Thanks Rob..
