house brick for stand, quick quetsion
  • CrocAu
    • Apr 2013
    • 164
    #106
    Re: house brick for stand, quick quetsion
    thanks for the feedback guys
    i don't know how but i managed to get up early today and get it all brickwork finished before it started raining, less than hour after i finished rain rocked up so lucky me
    • oasiscdm
      • Jan 2012
      • 1239
      #107
      Croc
      Shit that's how I can finish it quicker GET UP EARLY. hmmmmmm
      It was raining when I got up but I did stay up watching the Cricket.
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
      • CrocAu
        • Apr 2013
        • 164
        #108
        had great weather but done nothing today....
        don't you hate when work gets in the way of serious business
        • CrocAu
          • Apr 2013
          • 164
          #109
          for final step i'm going to put Perlite mix insulation but i think i would like to cover that with some sort of water proof render or paint? any recommendations for melbourne weather? best if some choice of colours was possible
          • brickie in oz
            • 3445
            #110
            Any acrylic exterior paint will be waterproof.
            • Bacterium
              • Apr 2007
              • 560
              #111
              Hey Brickie,
              I used this on my last oven but found there can be issues with it bubbling when you get moisture under the dome, invariably you get some.
              What about something purpose specific, eg. An acrylic render coating that has some permeability?
              Damon
              Build #1
              Build #2 (Current)
              • brickie in oz
                • 3445
                #112
                If it can let it out it can also let it in.
                I used an acrylic paint on my first oven which sat outside in the weather and didnt see any probs.
                My current oven has a roof on it and it sits underneath a roof too, kind of like belts and braces to keep your pants up.
                  Hey Brickie,
                  The trick to avoid moisture bubbles under the waterproof coating is to eliminate all the water first. This means about 10 decent cooking fires after the outer shell is complete.If you have these moisture bubbles then sand them off, fire the oven until all the moisture has been driven off (throw some plastic sheeting over the oven to check for moisture condensing under it) then when dry recoat.
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #114
                    Hi
                    I get the idea of throwing plastic sheet over to check condensation, coming out of the oven when curing [had discussion with Doug about doing this]. I am assuming you only leave it there until ?????????? But I have found if you cover the oven with plastic sheet [no curing fire] as I did and sun gets on it, it will create condensation. That was happening to me when initially I was covering my oven with plastic sheet. It created moisture below it where I didn't want it [soaked into the calsil].
                    So I guess fire it up check for condensation remove it at some point.
                    Cheers Colin
                    Oven 1 Completed
                      Originally posted by oasiscdm
                      Hi
                      Yes, only use it to test if moisture is there, otherwise remove it so the moisture can escape to the atmosphere.
                      • Greenman
                        • Feb 2013
                        • 1123
                        #116
                        I used Dulux Acratex. It has the advantage of texture that helps cover minor imperfections. Otherwise I guess the outdoor acrylic paint will cut it.
                        Cheers ......... Steve
                        • CrocAu
                          • Apr 2013
                          • 164
                          #117
                          some great ideas to consider, thanks guys
                          this is my current stage, only 4 bricks to go at the landing and then insulation job and i'm DONE
                          • oasiscdm
                            • Jan 2012
                            • 1239
                            #118
                            Thanks David cleared it up. Ta
                            Cheers Colin
                            Oven 1 Completed
                            • CrocAu
                              • Apr 2013
                              • 164
                              #119
                              front is now finished
                              i also installed 2 layers of ceramic blanket and wired it around with chicken mesh or whatever you call it, should put some extra wire to hold the blanket really firm?
                              • Greenman
                                • Feb 2013
                                • 1123
                                #120
                                Assuming that you are going to put a vermicrete layer over it and then stucco/render I wouldn't worry about it. The vermicrete will be the start of the shell and the outer layer will complete the shell. Incorporating a vent to allow any moisture that is trapped between the dome and the outer layers is a good idea.
                                Close to flame!
