I think lots of people miss it, or at least did in the past, which is why there were earlier builds that had to compensate for the arch and dome not wanting to intersect properly. If you go back and read the thread I linked to below, you can see I was only thinking of the lower intersection until Gulf helped me understand that the arch intersects the dome continuously but variably from bottom to top. Yes, I got the 620 from my cad sketch. When you make your cardboard layout, and have your arch form built (both things you should do before you get too far along) you can place the front of the form 620 from your oven center and use your IT or a tape measure to see how a top dead center arch brick will be "within" the dimensions of your inner and outer dome diameters. That is when you will know for sure you have it right. I can also help you find where the center of the oven should be on your hearth, but you will want to put your oven template on the location to double check. I always liked using models at work, but never trusted them enough to not do a spot check
