Re: Bread Maker Wanna-Be
Yes, I have had that steam experience too... it is a wonderful smell. Do I understand you begin with heavy (600g +) boules? I reasoned (probably irrationally) that lighter baguettes with less crumb would cook the most even at higher temps?
How long does your oven take to "recharge"? My vault doesn't lose a lot of heat but the hearth loses 50 to 75 degrees with each load... it'll come back up to within 20-30 degrees of where I started the initial bake if I let, but I get impatient and put the next load in pretty quick.
I'm still learning that the heat at the outside of the brick will move towards the inside of the oven to level out the heat... it seems counterintuitive that an oven without an active heat source will reheat itself... but of course the bricks are an active heat source.
Part of my problem is that this is still so new to me that experience hasn't taught me to trust the capabilities of the oven. For weeks I've been telling myself that I shouldn't keep a fire going past 7pm on Friday night so I can begin baking bread a little earlier (11am or so), but when the time comes I convince myself that last week was a fluke and just to be on the safe side I throw 2 or 3 more logs on the fire and put the door on around 8pm or 9pm. This last week I went through this and when I went to check the oven temp at 12:30pm on Sat. the temp was 680F... so I had to leave the door off for a while just to get the temp to drop for baking. I don't want to waste wood.
OC ). The hearth temp has normally dropped to the low 500s before I load them in and I get internal temps for the boules of the target 205F ish in that time frame. I have been impatient and thrown loaves into an oven that I know is too hot, but after the crust has set I will put them up on an inverted sheet pan and have had pretty good luck with reducing/eliminating the OC. With the large number of loaves in your oven, you're just going to have to find that sweet spot of heat and time for your oven and the type/size of loaf you've put together.
