My 3-Legged Dome
  • Dino_Pizza
    Re: My 3-Legged Dome
    Looks great George. I like all the sticks holding up the bricks. It's the best way so you can keep working on other stuff. I'm glade you went with a angle iron opening. I haven't seen one currently being built and I think it's a great option.
    Will the outer arch be an angle iron too or a brick arch?
  • WoodchuckDad
    Your progress is quite an inspiration. It's making me wish I had cut bricks today.
  • 100million
    nice work keep the pictures coming
  • fxpose
    Saturday night...
  • tfasz
    Nice work. I just got through that vent/dome transition as well and know it is not too easy. Yours looks nice and solid.
  • fxpose
    Did course 7 today...
  • fxpose
    Sixth course is now complete and I'm happy with the way things are turning out so far...
    I had one sleepless night thinking about the vent transition but once it was right there in front of you things just fell right into place. I worried for nothing...
  • fxpose
    I widened the thickness of the top of the entry by adding another angle iron. I'm feeling so much better now that I did this, and this morning I closed the course above it.
    Neil, I still have plenty of space in front for the vent.....about 11" in front at its deepest point and more than 20" across, in an arc shape.
    In fact, I'm thinking of using an old lid from my 22" Weber bbq kettle for the vent by cutting it in half and making a cutout for the 6" pipe. I'm hoping this will draw nicely.
    George
  • Neil2
    The space between the two angle irons could be the trough of your flue/vent.
  • fxpose
    Staring and pondering at the angle iron across the top of the inner entry before heading into work this morning I realized that I need to widen that cross top a bit more to support the full thickness of the course that will rest on top. I will add a second angle iron.
    George
  • fxpose
    Saturday...
    You and your camera will get dirty...
  • fxpose
    A little progress this week...
    I laid course 4 and part of course 5.
    Tomorrow, I'll figure out exactly how I'll bridge the rest of course 5. As the entry will be straight across at the top, I'll use an angle iron to bridge across like everyone else. I plan on using a 2" angle iron.
    This is also where I must decide the exact height of the entry which looks like a smidge over 9" straight across the top, as my revised oven height will probably end up being around 15". That gives me a 60% ratio.
    I'm wondering if 9" is too low for larger food items. It may be a little tight, but I'm thinking not.
    Edit: As long as I can stick my head inside I don't think 9" is too low...
  • Neil2
    "I doubt it, but I'm hoping this isn't going to cause a structural problem."
    Try it. If it is still standing when you put the last brick in, it is likely to stay standing.
  • fxpose
    Due to space constrictions up against a corner wall of my house I used 3" bricks for the first 3 courses. As you can see from the photo I now have enough clearance to use half bricks from the 4th course up. I doubt it, but I'm hoping this isn't going to cause a structural problem.
    My original plan was to go 3" all the way to the top.
    Any thoughts would be welcomed.
    Thanks,
    George
  • lwood
    Yes, the vent/transition area boggled my mind for about a week. But I finally figured it out.
