My Wood fired Redux
1 PhotoOld World Stone & Garden
John RuskinComment
Re: My Wood fired Redux
I still have to caulk in the top of the flashing, and I'm going to darken the finish on the chimney. I'm getting some staining from the capstone, because it is a touch too small. I used what I had...but I may change it out in the future. I actually don't mind the staining....I guess like how it doesn't bother some to see smoke stains on the face of the finishes.
John RuskinComment
John RuskinComment
Looks great, SC. Getting down to the finishing touches!My Build:
"Believe that you can and you're halfway there".Comment
I would not expect any thing else from you. Really cool ridge cap.Comment
Thanks fellas, almost there....Old World Stone & Garden
John RuskinComment
John RuskinComment
Proud papa, I can say they originally came from Utah.Comment
It's a pretty cool thing that started here. Who knows, maybe we can cull the best and have some really strong plants in a few years. I've lost a lot of them to blossom end rot and we're in a drought. But as you can see, the fruit looks very good. I'm going to get a few more and make some fresh sauce....I've got some 00 on day 2 ferment, so I'll let you know how they taste.
John RuskinComment
Water is the other significant factor in blossom end rot. Maintaining a consistent level of available moisture to the plant rather than a harsh cycle of wet and dry in conjunction with an adequate available calcium supply is the answer to managing it.
You can and probably will develop your own strain of tomato that will handle your local conditions better than what you started with.
More strength to the arm of those who develop area specific varieties to share for the common good.Cheers ......... Steve
Forno Food Pics https://www.facebook.com/media/set/?...1&l=1d5ce2a275Comment
We have been using a liquid spray application....seems to have done the trick.
Thanks guys......I had done some research and came up,with the same info on watering, see posts 386 and 388.Water is the other significant factor in blossom end rot. Maintaining a consistent level of available moisture to the plant rather than a harsh cycle of wet and dry in conjunction with an adequate available calcium supply is the answer to managing it.
It's been a really dry year here, and even with amended soil it's been tough to keep the moisture level where it needs to be. I am going to install an irrigation system next season.Old World Stone & Garden
John RuskinComment
. I just may, get on one of those "adult sized pamper" cruises to the "old country", before I croak
