Looks great and access to the oven from the new door will make life easier.
Looking very nice Mark. You will need a double flue for the roof penetration. I did one years ago (sorry pics lost from a computer crash), where I just did the double flue from around 200mmm below the roof penetration point to the top of the flue where you need a cowl with a double flue seating, as well as an orange Dektite seal between the roof and outer pipe. This way you don't need the added expense of a full length outer pipe.Kindled with zeal and fired with passion.
- Likes 1
Hi DavidOriginally posted by david s View PostLooking very nice Mark. You will need a double flue for the roof penetration. I did one years ago (sorry pics lost from a computer crash), where I just did the double flue from around 200mmm below the roof penetration point to the top of the flue where you need a cowl with a double flue seating, as well as an orange Dektite seal between the roof and outer pipe. This way you don't need the added expense of a full length outer pipe.
I'm not roofing the part over the oven, for now! I may roof it later in which case I need to do a triple flue in terms of our building code. In the mean time, I need have 3x pipe diameters clearance between the flue and anything combustible, so the big hole works well.My 42" build: https://community.fornobravo.com/for...ld-new-zealand
Here is an alternative method, that I personally prefer, because it does not require a double or triple flue that a roof penetration does. The oven mouth is well under cover, but its bum is out in the weather. As well as staying well away from flammable roof trusses, it also eliminates corrosive emissions falling on the roof around the penetration of steel roofing material. My sister had problems with that from a slow combustion stove, which required an expensive repair to the roof.
Last edited by david s; 01-14-2026, 04:55 AM.Kindled with zeal and fired with passion.
I like it! With my squirrel-tail flue position, the oven mouth is always dry. I may cover the gap with steel, no purlins, but I don't need to crank the flue. But good solution, none the less.Originally posted by david s View Post
Here is an alternative method, that I personally prefer, because it does not require a double or triple flue that a roof penetration does. The oven mouth is well under cover, but its bum is out in the weather. As well as staying well away from flammable roof trusses, it also eliminates corrosive emissions falling on the roof around the penetration of steel roofing material. My sister had problems with that from a slow combustion stove, which required an expensive repair to the roof.My 42" build: https://community.fornobravo.com/for...ld-new-zealand
