Michigan WFO
  • #31
    Re: Michigan WFO
    Looking good Mike - fire that puppy up!
    Les...
    • #32
      Re: Michigan WFO
      Its a little known fact of oven building, that the first three bricks are actually the hardest to get right... it looks good though, the rest aught to be smooth sailing.
      • #33
        Re: Michigan WFO
        Looking good. That's exactly how I'm going to do my next oven's connection to the landing- in this one I have them as separate items, not tied in, and I think yours is better, structurally.
        Elizabeth
        • #34
          Re: Michigan WFO
          What about this long, 10 inch vertical mortar line that seems to be in many ovens. Does this pose a structural problem?
          Mike - Saginaw, MI
          Picasa Web Album
          My oven build thread
          • #35
            Re: Michigan WFO
            Well, I don't know, really, from an engineering point of view. It isn't the same problem in mine as the long joint at the landing- I actually hung my dome on the arch some instead of using a mortar only joint inside it. I think that makes the forces even out somehow. But I'm not an engineering/physics kinda person, all I know is one doesn't seem to be a problem and the other one definitely was. I had to run another course of bricks up from the base on each side, with rebar in them, to keep it from falling over when I put on the vent stuff.
            Elizabeth
            • #36
              Re: Michigan WFO
              I played hooky today and finished the soldier course. It took much longer than I thought it would (all day!). I think it's because I don't really know what I'm doing.
              I didn't taper any of these bricks. I hope it works out OK. Some of the mortar joints were a little larger than I had hoped.
              Mike - Saginaw, MI
              Picasa Web Album
              • #37
                Re: Michigan WFO
                Mike - it looks like you are already cutting bricks at this course, what size are you aiming for? I believe I didn't start the taper until the third. Anyways, brick on my friend...
                Les...
                • #38
                  Re: Michigan WFO
                  Nobody ever does on their first oven... it'll work out fine, and looks great so far!
                  • #39
                    Re: Michigan WFO
                    All my joints weren't perfectly even either on the soldier course- but all my bricks weren't perfect. Some of them were sort of warped- if you put them side by side they curved away from each other. I figured that as long as I was as consistent as I could be without making myself a complete nut (not easy, since I'm already halfway there! ) it would be fine. So far, so good.
                    And like Frances said, we all went into it blind on the first go. Yours looks fine to me!
                    Elizabeth
                    • #40
                      Re: Michigan WFO
                      Originally posted by Les View Post
                      Mike - it looks like you are already cutting bricks at this course, what size are you aiming for? Les...
                      I just took a standard brick cut straight across. 4.5 inches, no bevel. I want the inside profile of the courses to all have uniform thickness, 2.25 inches. Therefore, I won't be cutting the inside face of the bricks if I can avoid it.
                      My soldier course has some outer mortar joints that are a little larger than others (hard to tell from my photo). Some are nearly 1 inch. No gap on the inside, though. I'm sure it should be OK, it's just larger than recommended on the Heat Stop 50 bag.
                      Mike - Saginaw, MI
                      Picasa Web Album
                      • #41
                        Re: Michigan WFO
                        Thanks for the encouragement. I squeaked in a little work today. Half of the second course is in before I was chased away by rain.
                        Mike - Saginaw, MI
                        Picasa Web Album
                        • #42
                          Re: Michigan WFO
                          Hi Mike, I too had some joints on the outer edges that seemed way to big, but I haven't had any problems with my oven. We have cooked 130 pizza's so far since the 4th of July, about 14 firings of the oven since the curing fires. As the dome starts rounding the curve to the top the outside needed lots of mortar too, sometimes an inch, but no cracks inside the dome, only some around the vent, but I think they are mostly between the vermiculite concrete and the outer layer of stucco. If you take a trip up north to see the fall colors in the next month you are more than welcome to stop by and check out my oven, maybe even have a pizza and a vino. I am planning on cooking all year, winter won't scare us!!! That's the story right now anyway. You are doing a great job from the pictures that you are posting, your oven will turn out fine. I have never done much of the masonary work, but everything is working great so far. Jim P.S. If you need vermiculite They have it at the new Menard's in Saginaw. I think it was less than $ 8.00 for the 4 cu. yrd. bag....
                          • #43
                            Re: Michigan WFO
                            Heyyyy Michigan... Me too. I am just finishing up my oven. Didn't go down four feet though. I just posted a picture of where I am on my "Michigan" oven I wonder what it will be like baking a loaf of bread with snow in your ear? We're about to find out. Already getting chilly here in West Michigan. Maybe we could name it "frostbite bread"
                            Peter
                            • #44
                              Re: Michigan WFO
                              Jim, Thanks for the invite! We just might take you up on that offer! I saw that vermiculite in Menard's. I was wondering if it was the right stuff, it seemed like a good price. I've been pretty happy with that place. I live within a mile, and it seems I'm there every day.
                              Mike - Saginaw, MI
                              Picasa Web Album
                              • #45
                                Re: Michigan WFO
                                I'm hoping the huge foundation was overkill. That just means my oven will last 500 years, while yours will only last 490
                                I saw your photo. It looks great. What an amazing location. Are those grapevines in the distance?
                                Mike - Saginaw, MI
                                Picasa Web Album
