Re: SE Minnesota insanity
Looks like the perfect spot to me! Don't tell the neighbors what you're up to... Keep them guessingKen H. - Kentucky
42" Pompeii
Digging the 48 inch deep (below the MN frostline) footings was the last discrete thing about the whole project. Then a truck with a 100 ft boom showed up to blow in the concrete for the hearth tower. After that, although they're still guessing, there was nothing clandestine about this!2 Photos
Nothing too subtle there. I am looking forward to seeing your build -- and your neighbors' reaction.
Good on ya' Eric.
This will be a fun one to watch.
JoeJoe
Originally posted by paulyboy View PostExcuse my ignorance. Your formwork is high, high, high.
Is this oven going to be accessed from inside the house?
Paul1 Photo
Nice. This is going to be such a cool set up. Have you begun work in the kitchen yet?
This is almost as insane as Brett favre leading the Minnesota Vikings to a 6-0 start to the football season!
This ought to be really cool!
Good luck with the build!
~BobMy Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
If you fail to plan, you plan to fail!
For the hidden amount of my tax dollars that goes into his 1 million per game, the Vikes better do something right this year!
Finally I am ready to lay the masonry. The FB boards are mushy in areas where they absorbed water from the concrete, so I'm trying to dry them out with a heater. At least the hearth is enclosed now, and I can work through the winter.
Hello All,
Today we nearly completed the (what I call) the "thermal containment area" for the indoor 36". The hearth is 2 inches FB board, 1 inch percrete, and 4 inches structural concrete. The outermost walls are cement board. The dome will be covered by 5 inches of ceramic blanket, leaving an air gap between the dome and the cement board. The hole you see is the outside access door for inspections/repair.
I also started laying out the floor and soldiers. As you can see there is quite a bit of space competition in my little garage. Next week the brick cutting begins in earnest!
Cheers,
Eric3 Photos
